Picked this bike up a couple weeks ago. Had a really bad top end tick.
Getting it home:
Got it in the garage and torn down, the tick was from this:
Everything else motor wise looked in great shape!:
I wanted a bit more snap, so I upped the compression to a wiseco 10.25:1 comp piston (stock 81mm bore):
Powroll small bore cam:
New Honda oem rockers:
Ported head:
I also snagged a Supertrapp exhaust from Kasey.
The plastic wear cracked pretty bad, so I dune cut them. I still need to fix a crack on the right side:
I took it out to the dunes on friday. I had messed with the jetting a bit at home. It was stock at 138, I upped to a 140. With that is went to a point in the rpm range and just stopped, like it hit a wall. I upped it 1 size and it started to cut out. I took the rocker cover off to see if the cam was on, which it was. I re adjusted the valves and took it to the dunes.
At the dunes i went up a jet size and it started getting better. The plug was reading ok and decent power around a 150 main. It only really had low end and some mid range, no top end really.
After each stop riding, I kept jetting up. I finally ended up having it a hair rich at a 162!!! WTF? I think it would be good at a 160, of course those are the only size I didn't have, the Tecate and 250r both like around a 160 main.
I also took some time and lowered the rear and softened the setting on the rear shock. So far it is a decent ride.
It has a rack welded on the grab bar which I do really like. I am also having an issue with the lights. I have one right low than works, left nothing, on high neither work.
Team Red Trike
My rides, 1985 ATC 350X, With legit Lamborghini Countach paint,2003 Harley Davidson FXDL Dyna Low Rider,customised the way I like it!
1997 GMC Sierra is gone, primary mode of transportation, 2008 Toyota Yaris!
