klt 200c
got this thing for free..dosent hold a charge ...what do i do...plus i was wondering if i can mount a tank where the "glove box" is and buy pass the fuel pump...i got it running and it did good till gas spewed out of the intake on the carb...i thank it sits at an angle ..it should b level right...and mabe its a float issue...my gf thinks im nuts for getting it for ferr..so help me get it going to prove her wrong..is there a free online manual out there? thanks dudes
ive got an 82 klt 200. i had the same problems, either the regulator rectifier is unhooked or faulty thats why your loosig charge the fuel pump is running down the battery, i had to get a pressure regulator after my fuel pump so the gas wouldnt flood it out, it was holding the floats up cause the amount of pressure. hope this helps some
Just finishing up an '81 klt 200 myself. It is tough to find much of anything part wise. I did see a fender on e-bay for $150 (used) . Haven't rode mine enough to tell ya about the fuel pump...I put a gas filter from the hardware store in it and changed the lines. Don't know too much about the carb as i am still dialing mine in... The charging system on the "81 is a dynamo located on the left (or shifter side). Look up the vin# to get a year and buy a manual...it's worth it. Type in kawasaki klt on ebay and you will find some parts. Good luck! I am taking pics of mine in the next week to post, although it's not mint, it has been 100% improved.
Welcome to 3ww. Post some pics of your bike.
I sent you the KLT info I have.
//ArrowChat Integreation Code
