I am trying to check compression in my 1985 200x. It starts and runs great but smokes sometimes.. Every few minutes though when riding it starts to smoke more and then will clear up after a few minutes.
Here is what I am wondering. How many times do I need to kick start it to get an actual compression reading. After 10 kicks with the choke closed and the throttle open it gets to 150-155 psi. I couldn't find any info on how many times you should kick it over to get an accurate reading. 10-12 seems a bit much..
I know the head valve cover gasket is leaking so I was going to do a top end gaskets and valve seals nut I wasn't sure about the piston. Spark plug is a little black but not soaked in oil.
