Results 1 to 15 of 29
Thread: I got me a 1977 ATC 90! *Now with pics*
    Beaver Falls, PA
    2,666
    Saw this on craigslist, called about it, and bought it an hour later... sitting in my garage awaiting 2 or 3 things to make it right. Starts and runs great, but needs an airbox hose, some wiring figured out(it will only run when the light is on hi beam), and the seat covered... $200, and around here, that's practically free You guys are seeing it before my wife even sees it (I don't think she wants to see it).
    Attached Thumbnails Attached Thumbnails 90-3..jpg   90-2..jpg   90-4..jpg   90-1..jpg   SS852367..jpg
    Jul 2008
    MD
    911
    I just got rid of my air box hose I had last night to someone local. I have the air box still but no hose.
    Jun 2009
    Leander TX
    2,217
    If the electrical is like mine (from a 78), the "headlight" switch as 3 positions: 1 = all off, 2 = ignition on, 3 = ignition + lights on. No hi-lo option even though the socket and bulb are capable.
    Sounds like somebody tried to make the hi-lo work.
    Beaver Falls, PA
    2,666
    Quote Originally Posted by jb2wheels View Post
    hmm... you have to have the switch o the headlight all the way to the right, and the handlebar ignition on for it to run... haven't tried it yet, but the previous owner said it will run in the middle position, but won't run well... will investigate in the AM
    Baltimore, MD
    6,088
    The switch on the thumb throttle is for the ignition. The switch on the headlight is for the headlight. If you have to turn the headlight on to run, then your wires are hooked up wrong, that's all. And for jb2wheels, your wiring is all hosed up man.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Monroe MI
    5,787
    ct
    1,396
    looking forward to seeing some pics.. Did you take her for a spin yet?
    Beaver Falls, PA
    2,666
    Quote Originally Posted by whyzee View Post
    I did... it feels like my 70 on steroids... lol. Until a month ago, I never rode a hardtail... fun!
    Baltimore, MD
    6,088
    MonroeMike is right, but some people post like they have no ignition switch (emergency switch). And I keep referring to later model wiring.
    Nicholson 185s
    ct
    1,396
    Quote Originally Posted by atc350xer View Post
    did you just buy this yesterday ?
    Beaver Falls, PA
    2,666
    Yes, around 8 last night, why?
    Also, did the 90's have a front brake? I'm thinking mine has a 110 front end because I have a front brake and the clamp spacing is different than the stock 90 triple I had lying around. I wanted to put the original handlebars on it, so I tried to do a swap, spacing between clamps is different, then I tried to replace the top of the triple, and the holes don't line up...
    6,810
    90 and 110 dont have front brakes it might be off a 125m or 185s/200 exc
    6,810
    if no front shocks then it prob a 125m front end or an older 200/185.
    Beaver Falls, PA
    2,666
    It has a 22" front tire... fits right with the fender... doesn't the 200 have a 25" tire?
    6,810
    So I guess you answered your own question its a 125m front end LOL .
