Results 1 to 11 of 11
Thread: ATC 90 restoration update.
    Wisconsin
    201
    Waiting on the cylinder. Then it will go to the machine shop to get bored. Fenders and tank are in the works.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    110 cylinder/ timing chain
    Front drum brakes
    Brush guard
    Complete rebuild to a 122cc
    Complete frame off restoration.
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    Complete rebuild to 122cc
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    Sep 2009
    Washington
    553
    Nice...I like the color scheme..
    2) 1977 Honda ATC90
    2)1985 Tecate
    2005 Banshee LE
    01 Honda 300EX
    74 Suzuki TC100
    66 Honda 305 Scrambler
    Wisconsin
    201
    Thanks, the fenders and tank are going to be white
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    Front drum brakes
    Brush guard
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    Beaver Falls, PA
    2,666
    It'll look like the big brother of Kasey's 70... nice paint!
    Jun 2009
    Leander TX
    2,217
    Your color scheme is just like mine and it looks great!!
    Are you painting plastic fenders? I did a BC/CC on my fiberglass rear fenders and metal tank but I did not paint my front fender.
    Wisconsin
    201
    I painted the front fender white. I will have more pics soon.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    Front drum brakes
    Brush guard
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    Wisconsin
    201
    Its coming together nicely.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    Front drum brakes
    Brush guard
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    Feb 2003
    Australia
    927
    Don't forget to bore your engine cases and get some 110 head studs.
    Wisconsin
    201
    Machine shop wouldn't bore the case, so I took a 60 grit flap wheel and a die grinder and opened it up to 57.8 mm. The cylinder and head are at the shop, waiting on them.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    Front drum brakes
    Brush guard
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    Wisconsin
    201
    Still waiting on the machine shop.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    Front drum brakes
    Brush guard
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    Monroe MI
    5,787
