Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: No spark on 1984 ATC200ES, Help Please
    Tionesta, PA
    5,747
    Do not confuse the CDI box with the pick up cover on the side of the motor that says "CDI". Your CDI box is a black plastic box. It will be located under the gas tank and it looks like this
    WNY
    517
    what is the thing under the housing marked "cdi" called? sorry for all the rookie questions.
    85 Big Red 250ES
    01 Scrambler 90 (Sons')
    Past Machines:
    96 Yamaha V-Max 600, 86 200x, 84 200es, 82 70, 82 200, 03 Bombardier DS650, 93 Ski-doo Formula Plus, 87 Ski-doo Stratos, 83 Yamaha XT550, 82 Kawasaki KDX175. 84 Tecate, 86 Tri-Z, 91 CR250.
    WNY
    517
    well i have spark now and i got it running! no smoke and tranny seems real strong. i dont know what i did maybe the part of the head i was holding the plug against was too oxidized or something. i dont know. it has a miss in the throttle. one of the headpipe bolts are missing and the other one is loose so hopefully after i fix that my miss will go away. but im stoked for now.
    85 Big Red 250ES
    Past Machines:
    tundrawolf is offline At The Back Of The Pack Arm chair racerFirst time rider
    High desert, CA
    176
    That's great news! Anyone have a schematic for this model? I'd like to look into the neutral light thing.
    Monroe MI
    5,787
    High desert, CA
    176
    If the battery is connected, and the neutral switch is disconnected, does it get spark, then?
    Pacific NW
    4,255
    Quote Originally Posted by tundrawolf View Post
    ahh HA!
    bingo another twist.
    Since we know these 200 es models will run withOUT a battery, that means no neutral light no neutral safety switch activated etc etc (in theory) The neutral light might try to glow when you try to pull start it withOUT the battery hooked up.
    If you read my previous post, mine would only fire if the neutral light was OFF.
    Battery connected, neutrallight on? NO spark.
    Battery DISconnected so obviously no neutral light..SPARK!
    Neutral light on? NO spark
    so now here's your question...I think the neutral light neutral safety switch just keeps the starter from spinning but now I gotta check.
    Thanks
    oh, I also heard the of you ground the neutral safety switch wire , it kinda bypasses it and will allow it to run or start or something but your neutrallight will always be on, even when its in gear. AND it COULD start in gear~~~~~~!!!!!!!!!!!!!!!!!
    ..but it bypasses the question of whether your neutral switch is messing you up.
    WNY
    517
    when i sanded down the rotor and pick-up under the cover marked cdi i moved the rotor without pulling it over. could that be causing my miss? if so how do i get it set again? i dont have a battery for this anymore. i got rid of it because it was dead. when i pull it over my neutral light illuminates and when i put it in reverse the reverse illuminates without a battery.
    85 Big Red 250ES
    Past Machines:
    High desert, CA
    176
    Dr. Joe, technically all the neutral light indicator switch does is provide ground to illuminate a light in the dash, and provide ground for the starter button, as a secondary switch for the starter system. Technically, in the case of the starter bypass relay, if you disconnect the neutral safety switch, you will not be able to use the starter motor, unless you permanently ground it, in which case you are right-the neutral light would always be on and you WILL be able to start it in gear.
    Now, here's a question: Obviously without the battery you are on pull start duty, but with the battery and the light on, when you say you have no spark, is it by the pull start and electric start both?
    winters
    Grounding neutral switch
    Hi folks,
    Having similar issues here. Can anyone tell me how to ground the neutral switch? I see one two-prong plug (yellow) and one single connector (red) leading up from the neutral switch. Which wires need to be grounded permanently to the frame?
    Thanks!
    winters
    anyone know how to ground the neutral switch?
    Richland WA
    808
    "Runs great for a minute or a day and then either starts immediately or won't start for an hour or a day or 2. Then it has spark again, for no real good reason."
    Thats bad wiring/connectors. Electrical/electronic gizmos dont just stop and start working for no good reason.
    Dec 2009
    illinois
    1,765
    I had the very same problem with my 84 200es. Sometimes it would start and other days it would not have a spark at all, it was the CDI "969" box. I changed it and it fixed it, ran perfect and started every time after that. The 1985 HONDA TRX125 ATV has the same CDI 969 BOX AS THE 1984 200ES BIG RED . """" one other thing!!! DO NOT ATTEMPT TO USE JUMPER CABLES TO START IT! THIS WILL DAMAGE YOUR CDI AND WIRING , A car battery has too stronge of a voltage. I beleive this is what happened to my CDI.
    cbx1170's Avatar
    cbx1170 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Phoenix AZ USA
    224
    neutral light switch wire is light green ... and on many Hondas and I think this one had a red tracer line down it. Ground that and light is on all time and will start even if in gear. DO NOT sand pulser / magnets on advancer under CDI cover. Clean them. Contact cleaner derust / remove red rust oxide Scotch brite mayyybe. lube advancer bushings/sleeves. careful advancer can be assy 180 off. slightly tighten springs if needed.
    Or go here and read its a little long but it works. "84 Big Red 200S Runs then looses spark" 2 wks ago.
    I have jump started hundreds of bikes atcs atvs pwcs power products ALL BRANDS and never damaged any part of elec system OTHER than accidentally by stupidly reversing jump cables. the individual systems only draws what it needs, current wise, as long as the voltage is correct.
  15. #30
    cox's Avatar
    cox is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    Edmonton alberta canada
    552
    I dont see a voltage difference between automotive and ATV/utility batteries. I have used my Optima redtop to jump my 200ES many times with no issues. Correct me if im wrong, cause ill stop using it then..... lol
    R.I.P. Yamahondaman
    Still practicing my NoobiX cube, take it easy on me...
    1982 Yamaha YT175J ( Not much left but the 's)
    1982 Yamaha YT175J
    1983 Yamaha YT125K + 175J =
    1984 ATC 200ES BR - running again - Camchain noise holding me back....
    1984 ATC70 -SOLD-
