Thread: 84 200es Engine Removal ??
    Mar 2008
    Northern IL
    18
    Trying to pull the engine from my 84 200es-all bolts are off, and it's flopping, but can't figure out how to disconnect the driveshaft from the engine??
    The service manual doesn't cover this-it shows chain drive, not shaft drive, aarrgghh!
    Any help is appreciated!
    Tionesta, PA
    5,747
    It should pull right out - it is just a slip yoke holding it together. If all else fails - the entire rear end comes off with 2 bolts / nuts. Pull that off and your drive shaft will come out with it.
    Mar 2008
    Northern IL
    18
    Thanks atctim!! That's exactly what I needed to know-greatly appreciate the help.
    Monroe MI
    5,787
