Results 1 to 11 of 11
Thread: Petcock issues 85 R
    COLORADO
    685
    Petcock issues 85 R
    This is really cheesing me off.....
    The petcock on my R keeps dribbling when in the OFF position. Ive looked at the rubber disc, spring washer, and all parts, it all checks out OK, is this a defect on these or is it just excessively worn?????
    Also carb overflows, but got that answered, carb rebuild kit and float is on its way.
    P***es me off.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    Apr 2010
    butler ky
    7
    Replace it with a aftermarket Pingel fuel petcock they are the best
    Apr 2008
    NW, IND.
    842
    Did you clean the surface of the shut off it's self where it meets the surface of the rubber?The rubber gets scored from the ruff surface of the valve. I've used steel wool to clean it(valve surface) and metal polish to totally smooth it out. If the rubber is scored, I've used a super thin coat of RTV sealant.
    Also the spring steel ring which adds pressure to the seal, LIGHTLY bend it more(if it needs it) to add tension. If the threads are wore down at the petcock bowl use teflon tape to reseal. Hope one of these helps ...Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Apr 2010
    KC, MO
    64
    I rebuilt my carb all ready but im wondering where is the best or cheapest place to get floats and petcock?
    Apr 2010
    butler ky
    7
    Quote Originally Posted by Macdiesel View Post
    carb parts warehouse for your carb parts pet cock ebay for cheapest a pingel will set you back that why they are the best
    Oregon
    2,471
    Are you guy's kidding me !
    CheapCycleparts.com ( Click on the link in our Fourm ) Buy a dam NEW PetCock ...
    It's 25 years old
    Nov 2009
    1,147
    Sometimes some motor oil on the rubber disk will let it swell some since it is probably 25 years old and really dry.
    Feb 2009
    michigan
    2,387
    just put a new one in it,they are not that much
    1985 ATC 250R
    . Team Red Trike
    Oct 2006
    2,502
    $61.92, I suspect buying new may help to keep them available and not becoming disco like all the other parts.
    http://www.cheapcycleparts.com/model...ssemblies/6149
    COLORADO
    685
    Quote Originally Posted by Mr. Clean View Post
    Hell yeah, I am getting either a new one or a pingel. I run pingels on all my Harleys and they work. Thanks Mr. Clean!
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Monroe MI
    5,787
