Thread: ATC110 leaking oil
    chula vista
    72
    ATC110 leaking oil
    ok guys so i got this thing running woo hooo great feeling when sshe lit up after a few pulls now she lights up after second pull great im still trying to get the carb dialed in right but my problem now is that it's leaking oil from where the front engine mount is i had to exange the mount with a mount from a atc90 because im using a nadito frame that i think is for atc90 motor, anyways what did i do wrong ? i tighned it up but now it's leaking oil from there? if the gasket isnt good can i make a new one ? i couldnt find one in ebay thanks for everyone help you guys have been really helpfull if it wasnt for this forum i wouldnt have this 31 yeard old three wheeler running thanks again
    Attached Thumbnails Attached Thumbnails IMG00317-20100423-1927.jpg   IMG00319-20100423-1927.jpg
    "Never look down on someone, unless your helping them get back up"
    lardog's Avatar
    lardog is offline At The Back Of The Pack Arm chair racerFirst time rider
    north san diego county
    172
    You definately need a new gasket . The acorn not goes on the bottom left. Torque the nuts to 18 ft. lbs. This should fix your oil leak..
    chula vista
    72
    ok so where exactly does the acorn go? thanks
    Baltimore, MD
    6,088
    Also there should be copper washers under those nuts.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    6,810
    Honda was pretty cheap so they usually only gave you 1 copper washer and it goes with the acorn nut . If your looking at the top of the head from the front of the trike it would be the bottom right head bolt .
    Monroe MI
    5,787
    1,736
    you can make a new gasket, i have sheets of gasket material and have made my own lots of times with good results, use a little yamabond with it (any engine gasket sealer) also im pretty sure i have seen full topend gasket kits for atc110s on ebay, might not be able to get the one u need individually but as a kit you could get one. but at my honda dealer alot of gaskets are still avaiable, check there, ya never know.
