Results 1 to 14 of 14
Thread: 200x to Auto X conversion
    mike1979 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    Michigan
    406
    I know this has been posted before but I nave NO luck with the search feature...
    What is the best years and model 200 motor to use in the 200x
    I dont really want to fab or mod anything. Also, would I need to use the front sprocket from the 200x or are they the same.
    And what about the 185 vs 200? Is there an noticable difference in power,speed,torque??
    Thanks in advance for the info and if anyone between Lansing and Detroit Metro Airport has a motor let me know, I make the drive everyday.
    Worcester, MA
    1,117
    I haven't noticed any difference in the 185 vs 200 stock engines. Supposedly, they are actually only 12cc difference.
    Any chain driven ATC 200 engine will work, you may have trouble with the models with electric start fitting as the starter motor *may* rub the frame (easy to fix, just a heads up)
    You will need to use another brake lever, as the X one is on the engine (I think?) or at least it doesn't stick out as far with the 'non-x' engines in there.
    185
    200
    200s
    185s
    200m (e start)
    Maybe the 200e if it was chain driven
    Sprockets should interchange, use the X one if your chain doesn't fit with the other 200 engine's sprocket (real easy to change)
    az
    2,001
    you'll need the 200X intake, the hardtail intake puts the carb right under the spine of the trike. jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    Oct 2007
    SouthShore - MA
    653
    Theres a nice write up in the file section. Really detailed step-by-step. I would like to do one of these someday.
    ^ Too bad you didn't get that SWELL machine yesterday John!!
    Hey, send me an email so my new PC has you on file would ya plz. I forget if your on there or not.....
    OP - Good luck with the auto X, allot of guys seem to love em
    Sep 2009
    Michigan
    406
    Quote Originally Posted by SeaBass8 View Post
    I looked for it, could you put up a link or tell me where the "file" section is?
    Monroe MI
    5,787
    Feb 2009
    Rome,NY
    1,046
    buy a 200s for cheap and part out what you don't need and ride it to make sure the clutch is good ...... I like the 185/200s brake pedal with a extra bend in it ... just my .02
    Missoula, MT
    4
    is ther any way to put a clutch on a 200s????
    *WOOT* MAH FENDER IS BROKEN????
    owned:
    '84? ATC 200s
    Manheim, PA
    5,817
    no................
    Feb 2009
    Toledo oh
    132
    mike pm me if you have any questions but that write up monroemike posted is pretty straight fwd.
    i think the hardest part of it was making the rear brake arm work. if need be i could maybe fab one up for you.
    parting 200x 250r 110 90 200s 350x
    honda 200 beater
    84 honda trx200
    85 200x newer and cleaner autox project
    My ebay store
    Oct 2007
    SouthShore - MA
    653
    Quote Originally Posted by mike1979 View Post
    Looks like MM linked it. Sorry actually took me a while to find it too. I forgot where it was. You gotta go to the "Old 3WW" link then the "scans" section.
    Good luck and post pics of your progress.
    Nov 2006
    Huffman TX
    891
    Quote Originally Posted by durza11 View Post
    Customize, and put a 200x motor in the 200s frame
    TRIKES
    1987 200x -First Trike-
    82 185s-SOLD!
    82 250r-SOLD!
    85 250es -the lil red hulk
    Quote Originally Posted by Midnite_rider View Post
    I like the outlook..... It ran fine before it broke!!!! it was flying before it exploded!!!! it was like new until I tore it up!!!!! LOL She was a virgin until last night??????
    litebulblsc's Avatar
    litebulblsc is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    LaSalle, MI
    313
    I have a 200s motor that needs a fresh bore and piston in Michigan. A little south of Detroit though...
    If you had a good 200x motor already, the top end would fit on the 200s bottom end
    And a red 2000 silverado
