Results 1 to 14 of 14
Thread: Need carb help Please
    pennslyvania
    18
    OK just got new piston and rings got all back togather and found jet needle was bent Go figure. Ok here is the question how to install new one and what should all settings be at. I see alot of diffrent numbers thrown at me but dont understand what they mean .. I have a rebuild kit coming so i will replace all jets how do I find right settings. Thanks
    haggard 2hundie's Avatar
    haggard 2hundie is offline Would rather be at the front of the train than Arm chair racerJust too addicted
    muscatine, iowa
    764
    it all depends on your machine, stock or after market pipe and air filter, to my understanding, if it affects air flow it will affect your jetting, get a owners/service manual and read carb jetting 101 undr world class help
    Manitoba
    536
    You need a service manual. If you let us know what trike you are working on, some kind soul might post up a link to a copy of one for it. It will tell you where to set the needle, and what are stock jets, idle mixture setting, etc.
    84 200x
    Monroe MI
    5,787
    pennslyvania
    18
    Thanks
    I have an 1983 250R with stock exaust and just bored to 71.25. Thank you for all the info and the manual will be a help im sure.
    pennslyvania
    18
    I have a 250R 1983.
    Feb 2009
    michigan
    2,387
    great trike dont f it up please
    1985 ATC 250R
    . Team Red Trike
    Apr 2010
    Oregon Dunes
    84
    rolman to actually answer your question and not just give a run around of links; stock you should be running a pe30 carb, a 130 main jet, a 50 slow, a 'ikb' needle- thats what the four pe 30 i got have. Have the air screw 1-1/4 tp 1 3/4 out. as for you idle screw i have found a good way to set it after rebuilding is to turn it out untill it dosn't lift the slider in the carb, then screw it in so it lets maybe 1mm of gap under the slider. I had your same setup and ran stock jettings at see level for years with 32:1 Castor Mix
    pennslyvania
    18
    Ok we will try I just dont understand how you get a 130 how do you measure..
    Beaver Falls, PA
    2,666
    there are numbers stamped on the jets
    pennslyvania
    18
    ooooohh ok so Im dumb.LOL Thanks wondering how where all those numbers everyone was giving.
    pennslyvania
    18
    well put new jets and still have bogging problem any suggestions. what position should Jet needle be at I have washer on bottom groove..
    bigbadktm's Avatar
    bigbadktm is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    San Diego, CA
    437
    start with the clip on the needle in the middle groove. bogging on top end or low speed bottom end stuff? move your clip to the middle groove and see if that helps your bogging. if you are running too rich, (lots of smoke) you need to go down numerically in size on the main jet. I have never had to mess with the pilot or slow jet, mostly because I am full throttle. Used to have a cherry 83 myself, now I have stepped up to the big leagues with an 85.
    hope that helps ya and there will be more info coming shortly from the other nice peeps on this board
    1985 250R
    FMF pipe and silencer, K&N, 4" extended swingarm
    pennslyvania
    18
    ok great will try that . its not rich im running really lean about 50.1 from take off has bogging. if take off slow seems ok but I will try moving it to middle. THANK YOU much
