Results 1 to 8 of 8
Thread: 200x starting issues
    mia
    4
    i have 83 200x starts up fine but then after i ride for a while and stall pr shut if off. i have to wait til it cools down before i can restart. it can be annoying. does anyone have any answers to my problem? thank you.
    Look right above your post at "forum purpose"
    Post this in Trikesylvania and you'll get more help. You can click on "edit thread" and then "delete" and get this out of here........
    Crest California
    3,014
    Sounds like you're overheating it, causing it to go into vapor lock, shutting down to prevent permanent damage.
    My XR200R's stroker engine does it all the time when it's warm out.
    My suggestion is to check the timing to make sure it's correct, check your idle needle adjustments (it could be running LEAN), check to make sure the heatsinks don't have 20lbs of mud stuffed in them, and then make sure you're using the correct oil. I always use 10w-30 in mine.
    LED obsessed
    2015 Yamaha FJ-09
    Feb 2009
    michigan
    2,387
    sounds like its lean alittle.does it backfire alot when letting off the throttle?
    1985 ATC 250R
    . Team Red Trike
    TommyBoy1971's Avatar
    TommyBoy1971 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Quinton, VA, United States
    161
    yeah sounds like its starving for fuel maybe
    Monroe MI
    5,787
    Have you checked to see if the gas tank is venting properly?
    Sep 2007
    100mi west of Chicago
    3,582
    Out of spec valves can cause this too, correct?
    Rob
    Anything can cause this.
    The engine requires three things to run- fuel, compression, and ignition. You're going to have to do some investigating when it dies and find out which one of these three you're missing.
