Results 1 to 9 of 9
Thread: 1985 250ES Big Red frustration
    Nov 2010
    Hartford Ky.
    8
    Hello newfound friends. Just registered here and trying to find out info. I have been using the search button for almost 2 hours now and am starting to get dizzy. Help! LOL I was searching for a wiring diagram for my 85 big red. I found one but it says on the schematic 1986-1987 ATC250ES nothing about 85. I also found a couple of threads on here where someone said the ignition system was different on the 85. I looked at several pages where users had links where you could download owners manuals. Again everything was labled 86 or 87. I never found anything labled 85. Does anyone have a link or answer to assist me. I thank you for any help in advance. My ignition keys from my 85 big red and my 87 250 fourtrax are the same, but I cant find the same color wires on the big red to plug into like they are on the fourtrax.
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    Found the 85-87 ES service manual
    Here it is: http://72.52.143.80/~trikes/Manuals/...vicemanual.pdf
    Wiring diagram for the 85 model is a pages 273-274
    (member on this site) has them all (or almost), that's where I found it.
    Hope this helps
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Nov 2010
    Hartford Ky.
    8
    what site is this on? I have tried this link on 4 different computers and none of them will pull it up?
    ailll1's Avatar
    Dec 2009
    Québec
    405
    Do you have Some kind of PDF reader? I'm not really good with computers but I think I use Acrobat 7.0 to read them.
    Got it from this thread: http://www.3wheelerworld.com/showthr...manual+updated
    Click on the first link and then go in manuals, after go in ATCmanuals and it should be there.
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Monroe MI
    5,787
    Nov 2010
    Hartford Ky.
    8
    Quote Originally Posted by ailll1 View Post
    Yes, I have the pdf reader. I should clarify. when I click on the link none of my computers I have access to would pull up the page at all. It wasnt that I couldn't read it, they all said that the page could not be displayed and that I might not be connected to the internet. I will try the new links given to me and keep my fingers crossed.
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    334
    It is a big file, 81MB. Right click and choose SAVE AS is the way to go.
    What kind of internet connection do you have?
    Nov 2010
    Hartford Ky.
    8
    Monroe Mikes links worked. Thanks to you both. I worked about 4 hours on the wiring today. I had it close enough one time that when I turned on the key the nuetral light would come on, but could get no power to the lights or start it with the start button. If I jump across the solenoid with a screwdriver it will start. I am afraid I will have to just strip the wires off and redo it all.
    Nov 2010
    Hartford Ky.
    8
    Quote Originally Posted by JustEnough View Post
    usually when a computer says that the link is bad, maybe a dot or dash in it somewhere that doesn't belong. Can you pull up the link in post 2? if so then my properties on internet explorer need tweaking, although I dont know exactly how.
