Results 1 to 6 of 6
Thread: 82 tri moto 125 chain adjustment
    Dec 2010
    lorain, ohio
    8
    hey guys, i bought a 82 tri moto125 a couple months ago and i was out riding the other day and the chain started skipping. i checked the teeth on both gears and they were fine, and i tried to tighten the adjuster but nothing moved. can someone tell me how to adjust it. also any video or any type of links would be helpful. thanks
    Nov 2009
    1,147
    There are 4 bolts that attach the carrier to the frame, loosen the bolts, tighten the adjuster, check the tightness through the inspection and oil hole on the chain cover.
    Dec 2010
    lorain, ohio
    8
    thanks, ill try that as soon as i get a chance
    Monroe MI
    5,787
    Nov 2009
    1,147
    For some reason I was under the impression that the YT175 and YT125 were the same, but I guess I never read the YT125 section.
    Dec 2010
    lorain, ohio
    8
    thanks a ton, this really helps me out. do you know anything about the lighting? all of my lights took a crap on me to. thanks
