Thread: Mikuni Carb help
    WB Michigan
    26
    Mikuni Carb help
    Hi guys torn my Mikuni 24 sh off my ytm 200 down to clean and had to replace a the need valve assembly. my ? is the three jets the big center jet must seat all the way since it has a oring to seat it. but the other two smaller ones do they seat all the way down or are they suppost to be a turn out or anything the one closest to the edge of hte carb has a spring too. I tryed to download the manual but my computer won;t let me for some reason. Thanks guys
    Monroe MI
    5,787
    VM22sh
    The one with the spring (#25) should be 2 turns out to start.
    http://www.xtremeusa.com/fiche_secti...r=1984&fveh=68
    The other two should be snug.
    Try right clicking and saving it to your hard drive, then open it.
    http://72.52.143.80/~trikes/ytm200&2...mer_manual.pdf
    If you still can't get it, let me know, I'll email it to you or something.
    WB Michigan
    26
    Thanks Mike, and I tryed that method for the file and it still won't open it, it will save it fine, but won't open it. If you want to email that would be cool I sent you a pm for my email address and thanks again for the help.
    Monroe MI
    5,787
    You need a PDF viewer to open it.
    http://get.adobe.com/reader/
    Uncheck the Google toolbar, unless you want it.
    or
    Foxit Reader (what I use).
    http://www.foxitsoftware.com/downloads/index.php
