Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: Please Begging for an answer!!
    Jan 2011
    mifflinburg
    525
    Angry Please Begging for an answer!!
    Ok this is the deal,
    I got a honda 185s pretty sure it's a 1983 because it has suspension front end. Just a couple question
    That i cannot seem to find answers anywhere else..
    Ok
    1. I just replaced the carb, Brand new i mean adjusted every whitch way..
    Can not seem to get it to pull start , I mean i must literally pull it behind a car until it gets warmed up a little. Then untie it and drive off.. Rides great after that untill i shut it off for about 10 to 15 min. Then i must do all over again.
    I mean when i shut it off after its warm. It will pull and start right up first pull..
    I have no idea..
    I mean i hate pullign this thing for 20 min for it to start then shut right back off..
    Anyway i heard it was spark plug. So brand new one, Heard carb, So brand new one..
    Cleaned petcoke and fuel line.. Dont know....
    2. Zomg, I have bought 2 manuals hoping it would help but nothing..
    Got my front suspension end off. Took tire off brake cables Etc... How the heck do i get the hub off the forks..
    Sheesh is there a bolt or something? I tried everything and the manuals suck.. No help at all..
    i dont know pictures will be nice also..
    Thanks in advance and ill upload photos tomorrow of my project..
    PA
    3,515
    low compression?
    WWW.HREATV.COM
    Monroe MI
    5,787
    Jan 2011
    mifflinburg
    525
    I dont have a meter to test compression but it seems healthy when i place my finger on spark plug hole and crank, Valves..... Hmmmmmm Any1 know what they should be..? Never checked..
    Fredericton, NB
    92
    If you're not using a factory Honda manual, then that would be your 1st problem.
    Aftermarket manuals generally suck, and cover too many years of model / models to sometimes give you the specific technical information you're looking for.
    A real factory manual will properly instruct you how to disassemble the front wheel / hub / axle...check timing on the motor, stock carb specs and adjusment...how to adjust the valves...etc.
    If you can't locate a good pdf copy of the factory manual, then check Ebay and spend a few bucks on one. Worth every penny if you work on your machines.
    Other than that, but I think the new carb is probably not a solution to your problem...nor a new spark plug.
    Long story short...get a good manual and go from there..."mickey-mousing" your motor is not going to solve your problems.
    Southern MN
    1,875
    Didnt you just say you had a manual or two? Use your head, and look in there, it shows you what to do.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Monroe MI
    5,787
    Jan 2011
    mifflinburg
    525
    Says nothign about the Problems starting it, And also i bought 2 1 off ebay and one at the honda dealership, Both suck they say lossen a bolt that i obviously do not see??
    Jan 2011
    mifflinburg
    525
    Damn see my manuals suck..Thanks Monroe!!!!!!!!!!!
    But anything on the starting problems?
    Would it be valve clearance?
    Springfield Mo
    3,309
    Sounds like it needs rings. Does it smoke abnormally? It is a four stroke so there should be little to no disable smoke.
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Jan 2011
    mifflinburg
    525
    Smokes very little.. Also i have another engine ready to be placed on this bike..
    Rings, Pistons are fine,
    Also yea it is a 4 stroke
    5 speed manual with no clutch
    Monroe MI
    5,787
    Quote Originally Posted by Headsup View Post
    Read troubleshooting on page 173 (18-1).
    Crest California
    3,014
    5 speed manual with no clutch?? Seems like it'd be hard to get into gear, no?
    As for the starting, sounds like it could be valves out of adjustment, or maybe an air leak possibly?
    LED obsessed
    2015 Yamaha FJ-09
    Jan 2011
    mifflinburg
    525
    it has a clutch but inside the motor.. Not a manual clutch..
    Width of a Photo id good for valve right?
    Jan 2011
    mifflinburg
    525
    aww sorry i forgot to say i have a 1983 with a suspension front end.. I cannot get hub out..
