Results 16 to 30 of 35
Thread: Please Begging for an answer!!
    Nightmare's Avatar
    Nightmare is offline At The Back Of The Pack Arm chair racerFirst time rider
    lehigh valley, PA
    196
    Dude your on a hard core trike forum! LOL. Most people here know twice as much as the average trouble shooter like yourself. Its a centifigual clutch by the way. Valve clearance should be .003 for each valve if my memory serves me correctly.
    Ride: 1986 Honda ATC 200x
    Following Mods Done:
    -Anodized blue block-off plate
    -Factory head light and master cylinder guard
    -ITP mudlite SP rear tire/Chengshin turf tamer front
    -DG reverse megaphone exhaust
    -UNI airfilter
    -Moose bars/Protaper Grips/MotionPRO twist Throttle
    -CEET classic ATC blue seat cover (should of sent it to mosh :-(...)
    -Tuned Carb with a 125 main jet
    -COMPLETELY restored gas tank
    -RED/WHITE PowerMadd Handguards
    -1/4" thick aluminum swing arm skid plate!
    Monroe MI
    5,787
    Quote Originally Posted by Headsup View Post
    it has a clutch but inside the motor.. Not a manual clutch..
    Width of a Photo id good for valve right?
    0.05 mm (0.002 in)
    Read page 21. ...and then some.
    Jan 2011
    mifflinburg
    525
    Ok to remove the hub it says...Loosen the front axel holder nuts,done remove the front axel and collor....
    HOW????does it just pull out??
    Whats "ZOMG"??
    You gotz zum readin and writin to do sonny!!!
    I'd become a heart surgeon if I were you..... Just sounds cool
    cox's Avatar
    cox is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    Edmonton alberta canada
    552
    ^^^lolz^^^
    R.I.P. Yamahondaman
    Still practicing my NoobiX cube, take it easy on me...
    1982 Yamaha YT175J ( Not much left but the 's)
    1982 Yamaha YT175J
    1983 Yamaha YT125K + 175J =
    1984 ATC 200ES BR - running again - Camchain noise holding me back....
    1984 ATC70 -SOLD-
    Jun 2009
    Leander TX
    2,217
    A picture or two would help...
    Jan 2011
    mifflinburg
    525
    Ill post pictures tomorrow please be sure to check in then.. thanks guys....
    Crest California
    3,014
    Remove the nut on one side then pull the axle out the other side. There are retaining collars that fit into the fork keep the axle from being slid out vertically.
    LED obsessed
    2015 Yamaha FJ-09
    Jan 2011
    mifflinburg
    525
    Ok i wasnt able to take pictures of my project but i will upload them..
    Anyway here is a picture of my front end.. Please help i cant get the hub off...
    Springfield Mo
    3,309
    Once you take the nut off the axle and have loosened the 4 nuts on the bottom the fork, the axle will need to be tapped, or maybe in your case, pounded out. Get a long screw driver, or a socket extension and use that to the axle through.
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Jan 2011
    mifflinburg
    525
    Ok so that is just a nut on the end??
    Wow mine is mengeled doesnt look like one...
    I have no special tools. But this is where i ran into my only problem, I am rebuilding this bike painting etc.. Sanding outside of motor down to be chrome again.. Ill upload pictures today..
    Anyway Lik ei said i have no air or impact gun.. Just my hands and a Ratchet with sockets..
    Maybe just try to give it brute force? Ok and after i take that nut off i pound the axel out? I thought it unscrewed from the other side??
    Thanks guys
    Also would u tell me if it is an 83? From suspension front ed im guessing yes? Always thought it was a 82 just with a different set of forks? idk
    Monroe MI
    5,787
    That is a "bolt", it is threaded into the right fork tube. Don't pound it out.
    #4
    http://www.xtremeusa.com/fiche_secti...1983&fveh=2792
    Jun 2009
    Leander TX
    2,217
    Looks like an 83. The axle threads in and you need to unscrew it. You are correct where you marked the pictures. That needs to unscrew. If it has unscrewed but still won't come out, you need a BFH and a drift and pound it out.
    It can be a real b#$%!@ after 28 years. I had 2 give me a real hard time last year. Lot's of things make it hard:
    - corrosion on the threads between the axle and fork
    - corrosion on the bearings and axle
    - corrosion on the spacers/collars and axle
    - front brakes totally trash
    - bent forks even slightly
    I'm a big ol boy and it took all I had and a 36" long 1/2" drive breaker bar to spin them out.
    Heat it.
    Soak it - WD40 or some other penetrant although I've heard some like ATF and acetone
    Repeat
    Good luck.
    Jan 2011
    mifflinburg
    525
    Ok yea looked like it was threaded into fork tube..
    So take nut off unscrew axel? Maybe with a rag around the axel and vise grips?
    Thanks a bunch guys.. Been working on this for ever.. My forks broke where the bar goes into the frame to hold it in place.. Um the neck or whatever..
    Tried welding no luck. Now i need to buy a set of forks but i need the hub.. Seeing that there is nothing wrong with it..
    Also is timing these machines hard?
    Wanted to take jug and stuff off to look at my rings but i dont wanna take it apart without getting it timmed.
    Heard u just line the dots up but the whole TDC thing i dont understand...
    Thanks Jb2wheels and monroe and every1 else who helped me.... Looks lik eit could be rusty where my axel threads into the forks looks like it anyway...
    Im 150 23 year old.. Strong but with a 6 Inch ratchet....
    Maybe ill try to soak it heat it soak it heat it..
    All else fails just look into getting a whole new front end...
    Standard 22" x 11 tire on the front i think
    Sorry u said acetone?? Like nail polish remover? lol?
    U think that would work? with a little WD
  15. #30
    Crest California
    3,014
    Timing can be tricky if you don't know what you're doing. The first time I tried to re-time an engine I put back together, I never got it right (wound up selling it actually..).
    Once you understand what you need to do, then it gets easier and easier to do. Being just one tooth off on the timing sprocket can screw the entire thing up. A genuine Honda shop manual is a very handy thing to have.
    LED obsessed
    2015 Yamaha FJ-09
