Thread: Need wiring help on a "81 185s
    Fort Smith AR.
    44
    Ok, I just scored a "81 185s for $25. The problem is it's been sitting for years, and someone stole the pull start and the cdi box(the little box next to the coil?)and rats have ate all of the wiring that was accessable to them. I have a repair manuel for it, but it dosn't list what color wires go where. It feels like it has good compression, but my compression gague does not fit the small spark plug hole, so I'm trying to figure out how to make it run without spending a bunch of money. Can enyone give me a wiring diagram of what goes where, or how to hotwire it to see if it even runs before I go spending a bunch of money on it? Any hely is greately appreciated. Thanks Dough
    Southern MN
    1,875
    It should show you a wiring diagram in the back of the manual, if not, check here, do a search for service manuals, and you will get an idea. If it is in that kind of condition, you have to expect to spend a little money on it, it not going to repair or replace worn parts on its own.
    It may be easier to buy a complete wiring harness, and CDI if the wires are that far gone. I have seen wiring harnesses on ebay for that model sell for about $10 or less. Just keep an eye out on there if you think you need one.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Monroe MI
    5,787
    Fort Smith AR.
    44
    Thanks Monroe thats just what I need. That should help me to see if it runs befor I dump any money in it.
    Fort Smith AR.
    44
    Yamaha I don't think you understand my problem. Even If I buy a cdi and wiring harness there is nothing to plug it into. I would need the pigtails off off everything electrical to make a harness work. I need to build my own wiring harness.
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    so make your own wireing harness, its not hard, i had to make one for my 200s. goes from STATOR COIL- pulse generator- coil- spark plugg. then put a kill switch/ light swtich inbetween and tail light or in my case blue neons LOL )
