I just picked up an 84 TRX200. I can start it right up with jumper cables attached, but when they're disconnected, it usually shuts right off. Strangely, the symptoms are somewhat intermittent. Today I warmed it up for a little bit and was able to run it without the cables attached and rode around for a while. After it sat for an hour or so, no start or idle without the cables. It has a totally dead battery but if everything is in order shouldn't it start right up with the pull start anyway? JD
LIVE IN EAST PA. OR NEW JERSEY THEN CHECK THIS OUT
