Results 1 to 11 of 11
Thread: 1985 200m
    Wichita, Kansas
    1,361
    1985 200m
    I Severly need some new sprockets/chain on my 200m. Looked at it and i think i could kill some one with it, damn thing is SHARP.
    What other sprockets fit the back and front? Do the 200s sprockets bolt up? 185s work? Can i get a setup for less than $50?
    Monroe MI
    5,787
    Wichita, Kansas
    1,361
    I saw that, was hopeing something cheaper would crop up >.<
    Mar 2007
    Texas
    5,045
    Ddue, that's 55$ for the chain, front and rear sprocket, that IS cheap. anythign cheaper woudol be used and worn liek what you got now. for my bikes i usually use the better stuff and I pay about $100 or so for the set.
    ________________
    https://www.mikesatvfix.com
    Wichita, Kansas
    1,361
    i know, i was just hopeing for cheaper, or an o ring chain. If you saw the trike, you'd understand lol.
    But if thats all there is, then thats what I'll get.
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    i paid 70$ alone for a good o-ring chain, another 30 for front sproket and another 50 for rear.
    Wichita, Kansas
    1,361
    Wichita, Kansas
    1,361
    For $50 you can get a really good x-ring chain, then cut it down to size http://cgi.ebay.com/ebaymotors/520-1...Q5fAccessories
    Nov 2010
    446
    i order mine cut to size lol, but i am from Canada and the part im from parts for trikes are expensive as sin. 1 stealer ship then theres Auto parts extra hahaha
    Mar 2007
    Texas
    5,045
    don;t get an o-ring chain. it's meant for street not off-road. it will trap the dust inside the links and turn to sand paper against the bearings. just get a good thick chain and you'll be fine. it is alsao less $ that way.
    ________________
    Wichita, Kansas
    1,361
    o-ring and x-ring chains are designed to keep dirt out. Only lubricate a chain with a dry lubricant. Otherwise it will attract dirt and dust.
    Some dry lubes:Finish line Dry Teflon lube, Blaster Dry Lube, Rock N Roll Absolute Dry Chain Lube,SRAM PitStop dry chain lube.
    Plenty of options, ?I found some stuff at ace hardware, it works great.
    non-o ring chains have the least amount of friction, less resistance, most power. They don't last as long though.
    o-ring cause friction in the chain, causing you to 'loose power' - enough to make those who race not use them. (they also remove extra screws to go fast)
    x-ring reduces the friction in the chain yet keeps it clean. Less power loss and longevity. This is the sweet spot - EXPENSIVE
