atc kill switch
I know this sounds retarded but do thes 85 atc 200x have kill switch or how do you kill motor cause i am tired of shocking myself pulling wire?
If it doesnt have a switch on the handle bars anymore,why dont you just pop the clutch and kill it than way? Is the thing hotwired or something?
ya it is hot wired i guess has plug on magneto i have to pull and it dont have manual clutch i am going try put toggle switch in and hope it work my throttle sticks and i have to hurry and pull plug
its not a 200x if it doesnt have a manual clutch.
i just ran number on tongue and that is what it said it was but probably a different set Up then
which ones come with semi automatic clutch
200, 200e, 200s, 200m, 200es as far as the 200's go. does it have rear suspension.
do not believe so this atc has been converted into a trike i know frame numbers bring up a 85 atc 200x
and it has pull start system whih is a pain recoil spring suks
Third wheel
yeah its def not a 200x...those are kick start with a manual clutch. if it has rear suspension it might be a other 200 cc engine in a 200x frame, if it doesnt its 100% non 200x
does have suspension who know on motor i rig up a toggle just rode it alot better
it is pictured below
Third wheel
//ArrowChat Integreation Code
