Hi guys!! I recently picked up a 1984 YTM225dx and need some info on it. What are common prbolems I should look for? It currently does not run and the guy says that he keeps bending valve anfter valve. I asked him if he timed it correctly and had no idea what he was doing when he rebuilt it. He said that he bought it with a bent valve and then changed the valve and let it idle for about 10 mins and the valve bent again as soon as he gave it gas. This is what he claims. I would think that speed of the engine wouldn't affect it because as the piston moved faster, so would the valves.
So I brought it home and got it all torn apart. The brand new exhaust valve in here was sitting on the piston. The piston and valve both appear to be okay. Basically i think maybe he had the timing off and went to start it and the valve hit the piston and locked up the motor and he didnt want to mess with it anymore. I would think the valve would be bent if the motor had been running when this happened. Does this sound right?
So after tearing it apart, I found that the aluminum collar that holds the camshaft in has a small amount of play. That will be fixed after I do the basics to get this thing running to see if the tranny and rear end and that is all good. But my main concern was that the exhaust valve only opened a tiny bit until I adjusted the bolt on the rocker arm. now it opens about the same as the intake valve, but the adjuster bolt is pretty much bottomed out. Also, the gap between the rocker arm and top of the valve spring on the exhaust side is like half an inch. I measured this by simply lifting up the rocker arm while the tension from the camshaft was not pushing down the spring. I'm sure there is a technical term for this measurement. I can do this to the intake side, but the gap is so small that it would need to be measured with a feeler gauge or something. I would take it as this is not normal and could be what is causing my problems. Or maybe the guy just didnt have it timed right. I wish I would have checked the timing before tearing it all apart lol.
