Results 1 to 11 of 11
Thread: the idle knob is maxed out on my 85 250r, What to do
    Apr 2008
    lynchburg
    29
    When I bought the trike several years ago it would idle good with the knob barely up,but slowly I have been having to turn up the idle knob on the carb to keep the trike running. Now that it is maxed out I rekon it is time to address the problem. Who knows, maybe I have overlooked a simple adjustment, i just dont get much time to play with it these days. The motor has been ported and who knows what else complete with a re domed head that leaked when I got it. Only thing i have replaced is the reed assembly which is a v force. The old assembly had a stuffer and was grinded on in different places. I have taken the carb apart and attempted to make sure everything was clean. There was some gunk inside the idle knob, but I cleaned it with no real noticeable difference. The head is fixed and It seems to be running good besides the idle issues. A set of rings would probably make it run even better and maybe that is the problem. I did bring the trike out to Oregon, so the atmosphere & elevation have changed, I rekon by about 2000 feet, perhaps less, but the problem began long before i moved the trike.
    Any help will be greatly appreciated, Thanks!
    Cold Lake, Alberta, Canada
    3,019
    Is it possible that the idle screw is worn down? Or that a groove has worn into the slide?
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Apr 2008
    lynchburg
    29
    I don't know about the screw, but the slide seems pretty snug in it's housing. I was reading about timing on another idle based thread, could a jump in timing cause a crummy idle, can these motors jump time without quitting all together or burning up? I wish I know where my manual was. . .
    3,019
    Not sure about the timing but I can't see it being an issue with a two stroke. What I meant about the slide is that there is a groove in the side of the slide machined like a ramp that the idle screw rides in. If a groove starts the slide will drop lower into the carb body slowing the engine speed down.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Monroe MI
    5,787
    If your slide is grooved up, get a new slide.
    Other wise, try jumping up one size on the pilot jet...........
    Nov 2006
    southern oregon
    2,338
    is it still using a stock carb? if a keihin pj has been swapped on you may need to replace the choke plunger
    2-stroke lover
    Wichita, Kansas
    1,361
    I'd make life easy and get a carb kit. The jets might have a partial clog, but a carb kit can fix it all back up.
    Apr 2008
    lynchburg
    29
    I am not sure what model the carb is, tomorrow I will find out.
    Wichita, Kansas
    1,361
    In that case, a carb kit wont work - youll nee to get new jets for the trike + the kit, odds are that the kit wont come with the jets needed.
    Apr 2008
    lynchburg
    29
    The carb is a Keihin PJ. the main is a 145 that I have suspicions of being drilled out. I forget the pilot size, but Il find out later. .
