Results 1 to 3 of 3
Thread: yamaha yt 175
    Mar 2011
    oswego county ny
    111
    Lightbulb yamaha yt 175
    hello every one im new here and i have 2 three wheelers ones a ytm200 and i bought it for 250 needed a choke cable and i also boufght a yt175 for 100 needs some work will a carb off a ytm200 work on a yt175? any info on the 175 would be helpful
    Baltimore, MD
    6,088
    Welcome to the site. I would highly recommend trying to do a search for yt175 as there is tons of info on here. Info on stock and modded as well. There are a couple yt175 with aftermarket rear suspension kits on them as well as modded to take other topends with better porting and such and also manual clutch mod info as well. Use the term "pro tec" to help with your search. I even modded a set of ytm200 triple trees to fit on the yt175 to have a little more suspension travel to go along with my pro tec rear suspension kit.
    Sorry, I don't know if those carbs will switch or not. Yt175 carbs aren't too hard to find for rebuilding. You could always use a carb off a yamaha 175 2 stroke dirt bike, like the mx175 or the it175 or the dt175. Those dirtbike carbs have the advantage of the choke being only on the carb and not needing a long choke cable as well.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Monroe MI
    5,787
