Results 1 to 14 of 14
Thread: 250r shifter shaft woes. 1986 model.
    Dec 2006
    St. John's Newfoundland
    1,587
    Bought a very clean motor from Ceaserthethird and had it shipped to my end of the world. It was packed in the best you could every pack.
    Now I went to pick it up at the post office and they kindly dragged the container out across the floor and I see the container was busted open on the bottom and the only thing that was contacting the floor was thr shifter shaft spline.
    So last night I opened up the container and the only way that motor broke that container was a hard throwing around. Very thick padding all over the place. And the shifter shaft is bent.
    Very mad with post office. How much trouble to get a shifter shaft and seal? How much tear down ti replace this shaft?
    Thxs
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    MO
    90
    I may have an extra actually from the bottom end of a 85R. Should work.. I'll double check when I get home today. I "think" its in good shape.
    House Springs MO
    5,496
    Its been a while since I tore into one of these, but I believe the clutch cover has to come off and its under the clutch basket. It then slides out from the right side. I hope it didn't crack the case because this sucks to hear.
    Dec 2006
    1,587
    Well theres no damage outside minus the seal. Inside my fingers are crossed. Hopefully someone has one to sell me.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    Cut off the outside before you bang it through, it should slide right out. It's not worth damaging the case boss down there......
    Oregon
    2,471
    Good tip DC
    Dec 2006
    1,587
    Good tip for sure. Don't need to add to the damage on my own.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    NEPA
    7,051
    Very simple,remove the clutch cover,, remove clutch,,slides right out that side.
    Dec 2006
    1,587
    Thxs for the info. The service manual wouldnt load on my ipad to have a look. Now I just gotta get the parts and pray theres no internal damage.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    MO
    90
    OK just went out and took pics of mine. If you want it. One thing I noticed is it looks kinda mangled.. I;ll post the pics here in a few minutes.
    MO
    90
    Here they are. It looks OK, but the one side is mangled... I took a close up of that. Dont think I would use it. considering how much of a pain it would be to have to replace if it does not not work. But PM me if interested.
    Attached Thumbnails Attached Thumbnails 2011-04-05 09.06.58.jpg   2011-04-05 09.07.34.jpg   2011-04-05 09.09.00.jpg   2011-04-05 09.07.08.jpg
    Dec 2006
    1,587
    Thxs for the pics. I will keep it in mind. This motor is really clean so I am hoping to find a mint one. Can I still buy them new I wonder?
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    rustyhondas's Avatar
    rustyhondas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Missouri
    319
    bolt the lever on and see if it works still. it's not that critical. if it's not leaking or binding , just use it if you want.
    you could slip a jack handle over it or something and give it a few nudges to straiten it and throw a new seal on it. it will probably be fine for years
    86 atc 250r
    85 atc 70
    84 atc 200s
    05 650 rincon
    06 400at rancher
    93 lt80
    02 kx65
    Dec 2006
    1,587
    I can see the gap around the seal. It leaked out the bit of fluid that was in it thru there. I can't see trying to bend it back into shape helping me at this point. Thxs for the advice tho. I believe I am going try running it thru the gears before I buy parts.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
