Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: 350x CLARK TANK FITTING ISSUES HELP
    OHIO
    2,857
    Just got my new tank..part # 11393-02. Does not fit?? Measures 5 inches inside tank mounts...too narrow?? Tank shrouds will not even bolt up?? Anyone have problems with these tanks and fitting issues?? Could they have sent me a wrong tank? Numbers are just marked with sharpie.....no stamp. Got it off amazon.com........should have known Any help appreciated...thanks
    Maybe we could help better Andy if you put up a pic?
    blkstangman88's Avatar
    blkstangman88 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    marysville
    282
    My clarks tank was the same. U hafta put some muscle n spread it to fit. It's designed for a snug fit. Over time it'll stay but a new clarks tank must b man handled. Shrouds I had to drill n holes. I had new maier shrouds n I drilled holed to fit since they weren't pre drilled
    House Springs MO
    5,496
    Same here. Just spread it out and man handle it. It will go on.
    Mine didn't fit my SX back in 1998 without some work either.
    Now I only use IMS and the fit/finish/quality seem to be better..........
    newfane ny
    1,277
    my clark is a snug fit also but my stock tank shrouds fit well http://www.3wheelerworld.com/album.p...hmentid=116122
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    I had to push mine on with my chest as I spreaded it apart with both hands, but as Cattle-dog said, my shrouds came off my factory metal tank and bolted right up. That part would concern me.
    FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
    86 250R
    86 350X
    87 250sx
    85 200x/cb350 custom
    81 185s/200x/250r custom
    79 atc 70
    Mini-Trail z50, 110cc Pit Bike
    and many multi-wheeled machines
    OHIO
    2,857
    thanks for all the help. I put it on the heater vent in the house for an hour and still had to lube up mounts and give it hell!! The rear mounts are nowhere close, had to drill new hole in one side and the other will need a plate made. I am pretty dissappointed with it....my last one from clarke. It is better than risking a leak anyway.....just did not trust the jb weld. It really does not mesh well with fenders and I also had to redrill aftermarket shrouds?? Wow.........what a load of work for that much money..... Thanks
    newfane ny
    1,277
    i am shocked you are having so much trouble my rear bolt holes lined up with a little moving around and my fenders lined up to the tank great, i think you saw my 350x at raffas icefest with my clark tank. here is a picture of the fender/ tank meeting up well. http://www.3wheelerworld.com/album.p...hmentid=119390
    Feb 2008
    Pennsylvania
    2,306
    My clarke tank is an older one. It fits my x fine. The shrouds bolted right up without have to re-drill any holes. The rear fenders match up pretty well.
    '86 Honda Big Red 250es
    '85 Honda 250sx
    '87 Honda 250sx
    '85 Honda Atc 70
    '83 Honda Atc 70
    '00 Honda Trx 90 (sons ride)
    atc70/110
    here
    1,336
    This is common. Clarke's quality is slipping. http://www.3wheelerworld.com/showthr...ity&highlight=
    Mar 2008
    EastGreenbush, newyork
    3,494
    the one i just sold to bkm fit great. they are all snug on the rubbers, you can shoot some air in the petcock, and it spreads it right out, and slips right on. No issues with boltholes or mounting shrouds. Hope it fits yours bkm as good as it fit mine!
    House Springs MO
    5,496
    Quote Originally Posted by aldochina View Post
    Absolutely. Just snug like you said, manhandled it a little and she went right on.
    Ironbnder's Avatar
    Alexandria, La
    363
    I think you got the wrong tank. You should have questioned Clarke before altering the tank and making it non-returnable. I bought my tank 4 months ago. The quality in Clarke tanks, as stated above, has not dropped that bad since then. You should not have had to redrilled any holes or made any brackets. It is just an issue of spreading the bottom open a bit.
    86 250R
    86 350X
    87 250sx
    79 atc 70
    If it's a 350X tank it will have 2 plastic teardrops on the back lower point of the tank for the 350X for 8MM mounting bolts clearance, the rear does not mount like a 200X.........
    The 200X may have one center bolt in the back, I forget. Someone with a 1st generation can let you know......
    How about a pic? I have an old 350X Clarke in the shop. It fits, wanna buy it?
