OK I am going to buy a manual but in the mean time can anyone give me a pointer or two of where to start. The bike was running turned it off did some work to it and poof no spark. I have changed the plug a few weeks ago and it looks ok. Now maybe the 27 year old run switch flaked out, I am asuming since the bike has a crank start and a magneto style ignition like a lawnmower that the switch just grounds the coil to shut it off. So what wires could I pull off to check that out with an OHM meter. Also I pulled the recoil cover off and shined a light inside it looks really cruddy so maybe the crud is insulating the magnet from making current? I am going to try and pull the flywheel and at least try and clean it up.
Anyone out there have much for ideas or help I would appreaciate it.
110klt
