hey guys new to the fourm i was wondering how to re time the motor and if any one have a key switch for a yamaha ytm 200e also if any other yamaha parts will fit the ytm 200s
can anybody help me out with this
There's one here.
http://72.52.143.80/~trikes/ytm200&2...mer_manual.pdf
check your local dealer, a new switch is around 60$ I believe, and or check on ebay there are so many of these being stripped on there should be able to find one
ok thanks guys i also got a problem with them front tires bolt that goes threw the forks into the hub its siezed up i hit it with an impact but it wont let loose any suggestions
is the nut seized or is the entire shaft seized you can use a chisel to cut the nut off and save the threads in the axle if you are careful, but if the shaft is seized like on my 200 es it's going to require a different route of removal.
