Thread: 185s
    May 2011
    Michigan
    185s
    i need some input on how to tune the carb on my 83 185s, it idles high when in neutral but when in gear it is fine, any suggestions?
    Crest California
    3,014
    Because when it;s in gear there is a load on it, therefore, it will idle lower. There should be an idle adjustment screw on the side of the carb. Also, this belongs in TRIKESYLVANIA.
    LED obsessed
    2015 Yamaha FJ-09
    Pacific NW
    4,255
    Quote Originally Posted by travis174 View Post
    xpress may have nailed it.
    There are shop manuals under the 'world class help' section,
    and the 'trikesylvania' area gets Tons more 'fix it' traffic.
    Welcome to the best trike site you could hope to find.
    Monroe MI
    5,787
    May 2011
    Michigan
    thanks for the input guys, it doesnt matter what i do with the idle adjustment screw it slowly revs higher and higher in neutral
    Cold Lake, Alberta, Canada
    3,013
    Make sure your throttle cable moves freely and it's routed in its proper place. Too much tension on the cable will cause the machine to rev. Does it rev more when you turn the handlebars?
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
