mine in my 350X is stripped also. it is 12mm by 1.5 pitch. i purchased a time-sert kit. i am going to install it this weekend. they r MUCH better then a heli coil. but also very expensive. the kit comes with the drill, tap, the counter bore, 5 threaded sleeves, and sleeve driver. so i could do 5 drain plugs if i ever had to...LOL.
maybe if u wanted i could do mine then send u the kit and u could use one of the sleeves to fix the hole on yours and then send it back. just a thought.
time-serts r stronger and hold up longer and better then the stock engine case. it is a steel sleeve. check it out on the website.
TPC TRIKES
FSU Powersports
RNS Powdercoating
