Results 1 to 7 of 7
Thread: Going to do a 86 250r axle swap
    Cheyenne, WY
    89
    like the title says, i'll be swapping an axle that is bent, is there anything i should be extra careful or watch out for? i do have a shop manual for it
    House Springs MO
    5,494
    A torch is sometimes handy if its never been off. The axle nuts take huge ass wrenches and are reverse threads.
    Cheyenne, WY
    89
    Thank you much, i believe it has been out before because i believe the actual owner had swapped the wheel bearings.
    House Springs MO
    5,494
    If its been off before it should be no problem. Key work "should". Remove the brake caliper and bracket, loosen the axle nuts and remove the locking clip, splined sleeve and axle nuts, hubs, chain and sprocket, and slide it out from right to left if your looking at the back of the bike.
    Cheyenne, WY
    89
    that might be my biggest problem is the right side of the axle is bent from a wreck, thats why its being replaced. suppose i can figure out
    House Springs MO
    5,494
    Quote Originally Posted by elitespecialkid View Post
    If it won't come out and the axle is toast you can always cut it.
    Cheyenne, WY
    89
    I didn't think about that. Worse comes to worse i can do that
