Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: Identity this trike.
    Monroe MI
    5,787
    Enter the VIN here.
    http://atcvin.webs.com/
    Post the engine serial number (below the shifter).
    Jul 2011
    Mid South
    98
    I tried running the VIN and it came up as an 80 or 83 ATC 200 UNKNOWN SPECIFIC MODEL or something like that. I tried it a few different ways because they are some confusing C's and 0's in a row with a few light or partial impression and there are 6 numbers at the end that looks like a different font. How many numbers are supposed to be in a vin? I took the black paint off but might need to remove the red paint to see clearer.
    82 atc110
    82 atc200
    83 atc185s
    Whats old is new.
    Jul 2011
    Mid South
    98
    There are 17 total numbers and letters in the VIN.
    If what looks like an R is actually a B you have Decoding Results: 1982 ATC 200
    Engine # TB05E-210xxxx with 192cm on the cylinder
    82 atc110
    82 atc200
    83 atc185s
    Whats old is new.
    Monroe MI
    5,787
    1982 ATC 200 is TB05E-2100001~
    glendive, montana
    1,822
    it is a 200 just like my wife's so enough about the 185 guys, simple fact I have one identical to his sitting in my drive way right now, however I have had to make some changes with mine, but the 185 bottom end and the 200 bottom end are practically identical so I wouldn't worry about that. It is a big version, everyone forgets the s in 185's stands for sport which means smaller tires, and they weren't built until 83 according to honda parts house. Please correct me if I am wrong about any of this mike as I know you know your business. Now on to the rear fenders, there are no aftermarkets for them but last I saw you could still get them from honda parts house. they are pricey but will be originals. From what I see your front rim and tire are the wrong size it should be 25" just like the back, which is why it is labeled a big 200, you should down load a manual for the trike from here, http://www.oscarmayer.net/atc/manuals/ there won't be the exact manual for it but if you download the 200's manual it will be almost identical to your trike, plastics fuel tank and tire size is the difference, motor, wiring, and everything else should be the same or withing closeness for you to figure it out. good luck with your project. Brandon
    Jul 2011
    Mid South
    98
    What is the factory size tires for this trike? These Carlilse are probably whatever they had in stock at walmart or tractor supply.
    Hondapartshouse.com said the fenders aren't available. Will the older non-sport 185 fenders that had a trunk fit also?
    82 atc110
    82 atc200
    83 atc185s
    Whats old is new.
    glendive, montana
    1,822
    the tire size is 25-12-9. I just looked and I think you'll have better luck with 1984 200es fenders I have looked mine over between the two trikes and I am almost certain that it is a direct bolt on fit with little to no modification, just looked they are still available as well
    Jul 2011
    Mid South
    98
    I checked the tires and they are all 25-12-9. The front tire is just completely out of air after a few weeks. What is the factory brand and tread pattern?
    I found a factory 82 atc200 non-s right rear fender so I will keep looking for the rest.
    The gas tank could be an 83 185s but fits and I think it looks good. Is the 200 tank larger?
    82 atc110
    82 atc200
    83 atc185s
    Whats old is new.
    glendive, montana
    1,822
    I honestly couldn't tell you the factory tread pattern, but I believe they were all ohitsu's. Tanks wise outer shape was just barely different, and cap size was smaller on the older 200, but otherwise they are an exact match up for mounting. Before I converted to a yamaha plastic tank on mine I was borrowing my friends 83 185's tank as mine was toast. I also change the front forks to a ytm 200 forks, as it is the same tire size. thank god I am a machinist, it was a little interesting modding it to work, but nothing I couldn't do again if I had the right equipment, now mine is all black which kinda looks nice.
    Monroe MI
    5,787
