Results 1 to 8 of 8
Thread: 85 125m was running fine, died, now it has no spark....
    Jul 2011
    South New Jersey
    52
    Hey guys. I am new to any 3 wheeler forum, I have always been able to fix these things without help haha.
    I got this 85 125m off a kid at school, he had been sunk underwater, which i do with my 200s on a daily basis so i knew it needed nothing but a carb clean/tank clean etc.
    So i clean carb, new plug and it fires right up. runs like a champ all day, idles great, good throttle response, no smoke, nothing wrong with it
    I leave it idling to go in the house, as i am walking away i hear it die from an idle...go to restart and NOTHING, no spark at all using different plugs and even a spark tester.
    I am running it without the battery as the starter is shot, I turn the key on, pull it , and AS I pull it the neutral light lights up like normal, but has no spark.
    I'm leaning towards the coil, maybe?
    I have "above average" mechanical know-how, and a really good voltage tester with all the bells and whistles, so tell me what to start testing.
    Thanks guys. Wanna get my little 125 running again!
    Monroe MI
    5,787
    May 2011
    eden,ny
    3,481
    stator then cdi. no good test for a cdi other than swapping with a known good one. water in the flywheelcover? just went through that and had to replace the stator
    Lauderdale County, Alabama
    2,029
    Here's an idea: You know that little cover on the top end that says CDI? Take that off, and make sure the pulse gen is alright and the little key hasn't broke, come off, anything. That happened to me once and it took me FOREVER to figure out to look there.
    chuckiedog04's Avatar
    chuckiedog04 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2011
    minnesota
    369
    I also submurged my wheeler in water recently. mines a 81 honda 200. it still havent got it running yet, but i rolled mine in water and it was under for about two minutes. so i will have to get a new plug and carb clean.
    Jul 2011
    South New Jersey
    52
    Thanks for the fast responses
    I already took that CDI cover off a few days ago. checked everything, the magnet/surface and all that are very very close, and It spins fine (key is good)
    I just don't know what could have failed so rapidly as it was running, I'm thinking it's the stator or it's wiring.
    I Just started reading all that info up there ^^, looks like i got alot of testing to do. Hopefully i dont have to pin any wires or peel insulation back,
    Jul 2011
    South New Jersey
    52
    The pulse Generator and rotor gap looks pretty good, but i will check it with feeler gauges tomorrow.
    Jul 2011
    South New Jersey
    52
    ANyone know if a 1984 Stator will work on my 85 ? found one on ebay, I'd like to have a backup anyways
