Results 1 to 3 of 3
Thread: '83 ATC 70 Pull Starter Question
    House Springs MO
    5,494
    My 70's pull rope doesn't engage untill you pull the rope about half way out. I took off the starter and pulled on the rope and the little teeth seem to spring out pretty much as soon as you move the rope. The ring with the little window slots does have some wear on it and probably needs to be replaced. Would this cause the problem?
    Is there anything to look for because nothing is jumping out at me, but I also have not tore into it any further yet either.
    jordan_muirhead's Avatar
    jordan_muirhead is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2011
    Monticello, Arkansas
    316
    mine has been doing this on my 185s, Ive torn the pull-start apart and cleaned all the individual pieces, and it seems to help some
    "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools"
    "Trikes Owned-1983 Honda 185S- eBay 200x carb, and uni filter-Sold"
    1986 Honda Big Red 250ES
    I bleed Honda Red You Should Too
    Three Wheels Are Better Than Four
    R.I.P ROOSTER-Dustin Ray Ferguson(9-20-89)-(9-22-08)
    R.I.P Jesse Ray Cash(6-17-93)-(12-14-09)
    Jul 2011
    Cayce, SC USA
    11
    I just rebuilt one that was apart for years. When I first used it I had the same result, either engaged half way or not at all, or I could jerk it quick to get it. The top plate inside is called the friction plate, this has a fairly small (12mm x 25mm +/-)coil spring pushing it outward against the washer , replace that spring with a stiffer one and you should be good to go. Go on and clean/grease everything including the recoil spring while you're fooling with it.
    Hope this helps
