OK, wondering why the decompression cable would be broke on my 83 185s? can you buy a new one? how was the cable supposed to hook up?
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools"
"Trikes Owned-1983 Honda 185S- eBay 200x carb, and uni filter-Sold"
1986 Honda Big Red 250ES
I bleed Honda Red You Should Too
Three Wheels Are Better Than Four
R.I.P ROOSTER-Dustin Ray Ferguson(9-20-89)-(9-22-08)
R.I.P Jesse Ray Cash(6-17-93)-(12-14-09)
you should be able to manually pull back the decomp lever, it will only stay for one pull though. you can start it without the lever all together but if the engine decides to do something funny it will yank the rope back and might hurt your fingers. also it would take more strength, but s 180cc isnt that hard to turn over anyways. id just look up 185s decompression cable for sale you can probably find something. you can order the cable from your local honda dealer i bet, although it would probably be around 25 bucks, maybe more...
I find the decompression cable a big waste of time..it was all corroded on my 350x so I removed it. No problem starting it..though I am a big guy so my weight makes it easy.
The 185 should be pretty easy to start..I'd leave it off.
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
its really easy to start, just wanted everything on mine working, so i was wondering how the thing is supposed to be hooked up
Check the service manual, starts on page 20-15.
i just had to fix my 200s pull start rope broke, and to hook it all back up right takes some time(its a pain in the as s) the manual i had didnt really help a whole lot it gives you the basic idea of where things go, after it is hooked up in the recoil starter then the cable runs under the carb and there should be a place to the left of the lever(if your looking right at it) that holds the end of the cable casing and then the cable itself goes into the comp lever.
1985 atc 110 for sale
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
uni clamp on air filter
350x front end
