This is my story of how a 1987 Honda ATC 250R replica came to exist. Back in July of 2010 I worked a deal with a guy to buy and install a set of struts in his wife’s car in exchange for a mutt, multi-year liquid R in a box. She was rough, but mostly all there.[/ATTACH]
I caught this damned 3wheeler disease from fellow member and close friend “Cave Rider”. As much as I love his 85, and 86R I wanted to do something different, so I set out to build me an 87 250R. It was built with the utmost attention to detail with the limited information I could find. Most of the info for this build was available right here on 3ww under the “missing in action” posting. The very first step was breaking the bike down as far as it could be every nut, bolt, washer and seal. The frame was then sent out for low pressure sand blasting.
I work at a garage with an auto body shop so I went through the 1987 motorcycle paint chip book and matched an original OEM Honda part still in a bag (Chain roller mounting bracket). The body shop then laid 3mills of Honda red and 4mills of clear on the frame.
Shortly After getting the frame back from paint I was involved in a truck vs. motorcycle accident and being on the motorcycle I did not fair too well.
I was laid up for about 2 months before I could get back to the R. In that time Cave Rider did a complete overhaul on the motor/trans for me. Even put Honda bolts washers and seals in her for me. What a guy!(note: motor sidecover has been changed to 86 style with embossed gear pattern)
While I was trying to grow bones back together the R just hung out under the T.V. in Cave Riders shop patiently awaiting my return.
When I finally got back at it I had the swing arm sand blasted by fellow member BigRedRidr who does all my blasting (yet another great guy to have on the team). Then matching the paint on the still available pro-link sticker I had the swing arm painted and cleared.
All useable parts were either sand blasted or chemically striped, then primed, painted and cleared. Two coats of primer, three of color and then two of clear. I used dupli-color 500 degree engine enamel with ceramic primer, paint and clear on all hard parts with great results. I would highly recommend this paint it is very durable, gas and brake fluid resistant, available in many colors, sprays nice, it just plain works. The stuff is like $6 a can and I spent in the neighborhood of $100 or more in paint but this is one area that can make or break a restoration. Get the good stuff
ok at this point it wont let me add anymore pictures to this post so it looks like im going to have to do a part 2
