Results 1 to 14 of 14
Thread: Little Mistake :(
    Jan 2011
    mifflinburg
    525
    Little Mistake :(
    Ok so now after i redone my Rear end in my 85 250sx, I Decided to Read over the manual One more time Just to double check.
    So now that i am looking, I see a couple missing Pieces, Like a "Snap Ring" That goes on the outside of the Bearings.
    But i must Tear down the rear end again tomorrow, The "Wheel Hub Spacers" I seen was in a Certain way, SO i Stuck them in that same way.
    I Placed the Chamfered faces of the washers To the inside, Like facing each other.
    This picture from the manual However shows something i dont know. One looks Like its facing out (Towards the Tire) and then one that faces that same way sorta.
    Idk can u guys eXplain maybe?
    Does it matter if the Flat side of the spacer is a certain way? Or the Sloped (Chamfered) A certain way? Idk, Seemed to just fit right in over the lip on the axle So that's how i put it.
    Suppose im going to Coles tomorrow also
    May 2011
    eden,ny
    3,481
    looks like the manual answered it for you
    Jan 2011
    mifflinburg
    525
    Well not really.. I found a bunch of typos in the manual, And this must be another.. First it says to Face the Sloped Sides Out Towards the tire.. But in the Picture You can Obviously See that, that is not what is going on...
    The One is the Opposite Way Then they say to do so.. The pics show them Both faced the same way, As to their telling me to Face them Out away from Each other.. idk Maybe im not wording it right,,
    Sarnia, Ontario, Canada
    3,415
    Quote Originally Posted by Headsup View Post
    I was wondering that myself, the picture in the manual and the instructions seem to be contradicting themselves..mine is still apart from the differential overhaul while I'm waiting for the axle bearings/seals to arrive.
    Kinda like to do it right the 1st time...
    Perfect questions for DC
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Monroe MI
    5,787
    From the Clymer manual.
    Mar 2008
    EastGreenbush, newyork
    3,494
    goes to show you why the oficial honda manual is the only way to go!! you the man mike!
    Monroe MI
    5,787
    That's from the Clymer manual, I should have put that.
    Pacific NW
    4,255
    Always good to see things in print from a couple different sources,
    and mix in personal experience and suggestions from others, divide by 2 and hope it's all right.
    Hard to believe but anatomy book authors have been copying each others
    mistakes for ever, too.
    3,415
    OK so I think I found the official answer for 'headsup's question..
    1st the spacers are different left to right so you can't put them on the wrong side..second there the tapered edge of the spacer points in toward the bearing apparently to centre the axle.
    Also there is a shoulder on the spacer that fits onto the lip on the shaft so you pretty much know if it's on right..
    The book would have lead me to believe the same thing..but I looked at my axle which is still on the bench and the description is misleading, but the picture is correct.
    The chamfered edge(sloped) goes in, not out!!
    You got it right 'headsup'..leave it as it is!!
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Mar 2011
    Southern Jersey
    147
    When I re did my SX rear end you can only put the spacers on one way...the assembly (left axle tube) won't bolt back together if they are in the wrong way....
    1985 Honda 250SX
    1991 Suzuki LT230E
    1970 Sierra Trail Boss 6X6 (under restoration)
    They only physically go on one way; always look for wear marks to help give you a clue.......
    Sometimes, I need both books to get something together. Always take notes on teardown!!
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    good to know this as I will be rebuilding the diff on my SX soon.
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    3,415
    Quote Originally Posted by 1985BigRed250ES View Post
    You'll need this..
    http://cgi.ebay.com/ebaymotors/Honda...item27be132653
    The pinion bearing has a lock-ring in front of it..most of the other 'special tools' can be worked around. Not this one..some of the guys had ideas about it, but I did want to damage anything so I bought it.
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Jan 2011
    mifflinburg
    525
    Yes^^ The only way they come out is with the tool, Idk i wasnt about to try to rig up something for a 20 DOLLAR BEARING..
