Results 1 to 8 of 8
Thread: Are 85/86 350x sprockets interchangeable?!
    Nov 2010
    Oshawa, On, Canada
    2,123
    Hello, I just ordered new sprockets for my x, royal distributing said they did not have a listing for the 85, so they ordered 86 front/rear sprockets for me.
    I just read a thread saying that the rear sprocket is different, is this true? Will the 86 sprocket work with my 85?
    I'm pretty sure the fronts are the same, right?
    Need to know before i have to pay for one that doesn't even fit! And royal sucks for returns.... Thanks a lot guys.
    This is the thread I read. http://www.3wheelerworld.com/showthr...187#post975187
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Sep 2011
    Illinios
    149
    Backs will NOT interchange. I don't know about the front
    Nov 2010
    Oshawa, On, Canada
    2,123
    Sh*t. Okay, thanks a lot man.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    House Springs MO
    5,496
    They are different back sprockets. If you want to run the '86 rear you have to use the '86 bolts which are impossible to find sometimes. If you can find the bolts use the '86 setup because you can run a new billet carrier with the '86 setup. Later down the road if you want to use a new billet carrier you will have to switch to the '86 style anyways. The fronts are the same.
    Nov 2010
    Oshawa, On, Canada
    2,123
    Thanks a lot guys. I just called and cancelled my order. i guess i'll be ebaying a rear sprocket...
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    1987350x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2007
    Winnipeg, Canada
    267
    I can get the tapered bolts for the rear sprocket
    My Trikes: Past and Present
    1985 Yamaha TRI-Z
    1985 Kawasaki Tecate KXT250 (x2)
    1986 Honda 250R
    1986 Honda 350X
    Jun 2003
    englishtown NJ
    2,676
    I have a set of them, I can't use them on my 250r. They are too long to use.
    Aug 2010
    Southern Oregon Coast
    932
    if you have your stock 85 bearing carrier, just turn the sprocket around so the bevel is facing against the hub...
