here is the search I did
http://www.3wheelerworld.com/search....archid=7180961
Does anyone have a pdf file for one?
My ridez 110,110, Big Red, 185s, 70, 200, 250r!!!!
REQUEST YOUR ATC PART'S @ The 3 & 4 Wheeler Emporium
Hm strange i cant find it either now.. I know monroe Posted it 100+ times... Some where in world class help section, Ill keep looking and will reply when i find it
Thank you so much!
MonroeMike
you are the best thank you soooooooo much!
Well Crap!
Heres the problem last year whrn it last ran it ran great i had it rebuilt by my friend who works at honda I got it back from him and it ran great all last summer and winter in the snow. well when I got it out this year the pull rope recoil spring broke so I tryed to pull start it and it started but it has a HORRABLE knock in the top end somewhere. to i pulled the valve plate off and looked at the timeing chain and its popping ehrn i stick it in gear and spin the tires and its loose?
any ideas?
Thankz!
You need to tighten up the timing chain there should be adjusers on the motor the manual should tell you. Also do yearly maintenance to it like check and possiably change the oil, put fresh gas in it. Post some pics up of the trike
2nd pick, Behind the Top end there. the lock nut and bolt is the chain tensioner. Says in teh manual how to do it propely, I am not 100% sure anymore how to Adjust them
