Thread: New Member needs help with 200es wiring/charging
    Oct 2011
    Upstate Sc
    3
    Hello everyone, its my first post here and im working on the wiring on my 1984 Honda 200es. To begin with its not charging. I have ran the only test I know which is to check the resistance from the black and red wire out of the alternator to ground. It was 276 ohms which is in spec. Im not sure if this has anything to do with it but when the key is turned on, engine running or off, the neutral light will glow from dim to bright then repeat over and over slowly. Also the lights do this same pattern when turned on. I have no clue what is causing it to do this. Any and all help is very welcome! Thanks everyone!
    1984 Honda atc 200es
    Oct 2011
    Upstate Sc
    3
    Also my battery voltage will go up and down while running but never gets above 5-6 volts.
    Monroe MI
    5,787
    I would test the alternator charge coil, the voltage regulator and the charging circuit.
    Check out "Charging Circuit" page 84.
    http://www.3wheelerworld.com/showthr...0-Service-Data
    and/or
    Pages 16-4, 16-5 of the manual.
    http://72.52.143.80/~trikes/Manuals/...01984%20CD.pdf
    Oct 2011
    Upstate Sc
    3
    Thanks, those will be very helpful! Ill test a few things when I get home later today.
