Results 1 to 9 of 9
Thread: 198? trx125 help?
    Aug 2011
    WI
    9
    198? trx125 help?
    Hi, I recently purchased a 80's trx125 in need of work.Has been sitting outside for couple years.
    Did get the engine to start using starting fluid.
    Brakes need work, drive chain, frozen cables, rusted out gas tank, ripped seat and loose front end parts, water in pull start.
    I tore the carb apart and lots of corrosion and rust, got it cleaned as good as possible. Ripped a couple orings and float bowl gasket, still pitted from the corrosion. Would it be better to buy a rebuild kit or a new carb off ebay?
    thanks
    Apr 2003
    HARTFORD CT, USA
    478
    rebuild kit is $20 new carb is ?
    'WHEN IN DOUBT.........GAS IT!'
    87 KXT250B2 Tecate
    86 ATC250ES BIG RED
    85 ATC350X
    85 ATC70
    'A FEW IN PARTS'
    Jan 2011
    Brazil, Indiana
    2,087
    Sounds like you are going to have alot of money in it when you are done. You might as well count on replacing all of the wheel bearings too.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Aug 2011
    WI
    9
    Quote Originally Posted by RacerRichie View Post
    The carb I was looking at was a clone china carb around $30 on ebay.(Not sure on quality)
    Seem to be a few threads on it, carb being a hit or miss on working right.
    Hoosierlogger: Only paid $25 for it, figure can try to get it going. If it doesn't work out can always sell or part out.
    thanks
    Jan 2011
    Brazil, Indiana
    2,087
    Heck yeah you got alot of room before you spend too much on it then. The Chineese carbs are ok, I have one on my 110. It runs fine. Just take them apart and clean it real good before you put it on.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Aug 2011
    WI
    9
    Hi, got the carb on friday. Finally got around to installing it. Haven't got it started yet, is the 125 three wheeler
    manual the same as the trx125 minus front end parts?
    thanks
    thanks
    Monroe MI
    5,787
    Run the VIN and let me know the year. I will send you the correct TRX manual.
    http://www.motoverse.com/tools/vinDecoder.asp
    Aug 2011
    WI
    9
    Quote Originally Posted by MonroeMike View Post
    Hi, I'm fairy sure the atv is a 1985. Couldn't find anything except one sticker on the frame mostly missing though.
    Also found the frame is cracked in the rear.
    thanks
    Monroe MI
    5,787
