Results 1 to 15 of 16
Thread: 350x keeps blowing headlight bulbs
    Jun 2003
    Lake George, New York
    1,732
    I just got it going again and pretty much all mechanically sound but it keeps blowing bulbs. I checked the wires, they are all properly secured. I'm thinking voltage rectifier? Is there any way to test it? I have a multi-meter.
    Thanks!
    Cincinnati, OH
    3,289
    Check the wires where they go into the rubber part and see if there frayed, If not 99% of the time its the rectifier. Dunno if there is a way to test it .
    "MR.Clean"
    Pacific NW
    4,255
    Quote Originally Posted by AirManCam View Post
    Thanks!
    I can check the manual for rectifier test, if there is one.
    I know the old trail 90s used the battery to soak up the voltage spikes
    and all intact bulbs needed to be present
    and that all bulbs needed to be in and working or they'd pop...
    Never even seen a 350 so I'm assuming no battery/regulator.
    Just rectifier to run ignition and lights.?
    Grounds are good?
    Jun 2003
    1,732
    Yes sir, all wiring is good. I did remove the headlight to clean stuff up but I put all the wires back together and they are in the proper colored plugs, not sure if order matters but I don't see how it would because its two wires going to one wire as long as the colors are the same.
    Sarnia, Ontario, Canada
    3,415
    Hook up your volt meter to the headlamp circuit, set it to read volts DC..start and idle the bike and monitor and record it. Now give the throttle a couple revs, watch and record the readings from low rev to high rev, then finally hold it at a high idle for 20-30 seconds and record the results.
    Secondly, you said it keeps blowing bulbs..how many?? Are they going out on the same side or alternating left then right then left...??
    Let us know these results..I consulted the manual and it says the A/C regulator should be maintaining your voltage to 13.5-14.5V. There is a specific test in there for it also.
    You may have a faulty A/C regulator(rectifier) as you suspected.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Jun 2003
    1,732
    Quote Originally Posted by dougspcs View Post
    Thanks for the help, I'll check when I get back home I'm headed out of town on a hunting trip. It blew the ones that were in it, so I just replaced them and they blew too. I think the rectifier is bad because the last time I flipped them on I was riding it and they were super bright, almost looked like hid's..they didn't last long. They didn't blow in any specific order but one went before the other each time.
    3,415
    You'll probably see that high rev voltage is way over the 14.5 spec.
    From the symptoms you are probably on the right track..I wouldn't ride it until it's fixed. On a machine without a battery to help stabilize voltage I would be concerned about the high voltage damaging other components like the ignition module or coil!!
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Pacific NW
    4,255
    Great advice.
    I wish I had the test protocol for these.
    Hate to mention the trail 90 again but that has a taillight too that needs to be in the load
    sequence.
    Does a 350 have a taillight too?
    If so it may need one in the loop.
    so? the 350 and the 90 have rectifiers, often confused with a regulator?
    I think I've heard that ac is rectified in the cdi unit on some machines too, but certainly wouldn't bet expensive parts on that notion.
    Hampton, Virginia, C.S.A.
    2,664
    Quote Originally Posted by drjoe171 View Post
    Great advice.
    sequence.
    the 350x has a voltage regulator in the back near the grab bar...you do not have to have all bulbs in on the x the voltage reulator takes care of all that...id say its the regulator as well...i had this problem...my lights blew every time id rev it up
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Jun 2003
    1,732
    Great advice.
    sequence.
    Hmm, that's not a bad bet because the tail light is on it but its broken. I'll pick up a tail light and add that to the mix too its on my restoration list anyways. I just got it all mechanically sound and winters coming so I'll probably just rip it all apart and go through all of it.
    3,415
    'threewheelin' is right..bulb missing or being blown are not important. The voltage regulator does the work regardless of what bulbs are working..
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Rectifiers change AC to DC; Only needed when you need DC for a battery. Regulators maintain a given voltage parameter.......... Our lights are AC.
    Dec 2009
    BFE
    1,202
    The regulator on my 225 DX when crazy one time and it blew out all the bulbs on the bike headlight,tailight,even the neutral light. It sucked because I was riding home from a friends house at night. I replaced it and I haven't blown a bulb sense.
    "I'm Kind Of Like The Turtle Man Of 3Wheelers."
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Howdy's Avatar
    Celina, Ohio
    10,079
    There is a voltage regulator mounted near the back of the air box under the seat. Make sure it's hooked up properly. if it is it's possible it has went bad. When they go bad I normally replace them with an aftermarket "Volt Pack" ( lots cheaper ). Simple 2 wire hook up and wa-la your good to go.
    Howdy
    Jun 2003
    1,732
    Quote Originally Posted by Howdy View Post
    Howdy
    Thanks Howdy, do you have a link to said volt pack?
