Results 1 to 15 of 25
Thread: Good 4-stroke oil?
    Matrix's Avatar
    Matrix is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2011
    Newton Falls, Ohio
    379
    Good 4-stroke oil?
    I have actually searched the site for this but I did not see it. So whats some good oil to run? I run Honda HP2 pro racing oil in my 250r (not for egotistical reasons) would that work in my 200x and 185s? The previous owner didnt take the best care of this trike (200x) so I want to run something in it to maybe clean it, I ran sea-foam in my 185s twice and nothing bad happened so could I run it in my 200?
    Crest California
    3,014
    Any 10W-30 or 10W-40 motorcycle wet clutch style is perfectly fine. Literally, pick one, they all have to meet specific grades before they can be sold.
    LED obsessed
    2015 Yamaha FJ-09
    Tucson
    1,652
    Lets just stick with what xpress said!!!
    House Springs MO
    5,494
    You might want to consult with Fabiodriven. He is the resident oil guy and loves nothing more than a good discussion on oil. This is something that just doesn't get talked about a lot around here and I know he looks forward to some oily banter. As a matter of fact he once had written in his signature that we need more threads pertaining to oil.
    79fordblake's Avatar
    79fordblake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    Wingo, Ky
    278
    Well for what its worth I use Valvoline ATV 10w-40 in mine.
    1981 Honda 185s
    DG Exhaust, Clamp on Uni Air Filter
    '85 200x carb, 200 Cylinder (SOLD)
    1981 Honda 185s
    Straight Pipe, Uni Air Filter
    200x Carb, 200 cylinder (SOLD)
    1985 Honda 250ES Big Red
    Uni Air Filter
    1986 Honda 250ES Big Red
    Uni Air Filter
    RamsesRibb's Avatar
    RamsesRibb is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Louisiana
    316
    The best thing to run short of premium synthetic motorcycle oil is Rotella. You can buy it in bulk anywhere for pretty cheap and its packed with all the right additives.
    Previously known as HighFlying101 since 2003
    I changed my email and lost my password
    Current: '85 Tri-Z , '83 250r , '86 Tecate, '80 ATC110
    Prior: '85 FTZ ATC350X, '85 Tri-Z, '85 ATC200X w/ Bassani exhaust, '83 Big Red, '81 ATC185S, '79 ATC110
    http://www.ipetitions.com/petition/tpctrikes/
    Aug 2010
    Southern Oregon Coast
    932
    Oh, I can't wait for Fabio to chime in. There are oil threads all over the place,it seems.
    Oh and HP2 is two stroke oil....
    NEPA
    7,051
    Strap in tight boys,,,Here we go !!
    Sarnia, Ontario, Canada
    3,415
    Quote Originally Posted by Matrix View Post
    Are you talking about a lighter mix gas/oil in your 4 stroke? Or putting HP2 (2stroke oil) in the crankcase of your 4 strokes(NO, NO, NO)?? Just curious to know you understand the difference between a 2stroke and 4stroke!!!
    I'll assume you do and you want to throw a bit of mix gas in your tank of the 200x/185s. Well to start it isn't gonna clean anything..fact it will foul your plug pretty quickly depending on your mixture ratio.
    If your intention is to try and clean the top end out (combustion chamber, intake and exhaust valve...) then get a good spray combustion chamber cleaner and follow the instructions. Your seafoam idea is fine for the 200x also..
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Spring, Texas
    450
    I thought the newbie section was supposed to stop all this! I guess this is just the nature of the beast.
    85' 350x (newest addition)
    85' Tecate (Still dealing with electircal Issues!)
    85' Tri-Z (On the back burner)
    85' 200x (SOLD)
    Leave me Feedback: http://www.3wheelerworld.com/showthr...ack+for+ama009
    Beaver Falls, PA
    2,666
    ^^ Yeah I run the same (Castrol, not horse piss)^^
    Just a suggestion, but how about an oil thread sticky? We could put links to the millions of existing oil threads in there.
    Gold Hill, OR
    1,295
    We all wait for you to chime in this morning and thats all we get? An only half-sarcastic, civil responce? You're slipping Fabio
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
    Manitoba
    536
    I've run Rotella oil with the JASA-MA rating in my ATV's for years and never had a problem. JASO-MA rating ensures that it is wet clutch compatible.
    84 200x
    3,415
    just a suggestion, but how about an oil thread sticky? We could put links to the millions of existing oil threads in there.
    heeerrrrreeeessss johnny!!!!
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
