honda 200e big red key issues
ok i need some info about the ignition key on the 1982 honda 200e. Here is the problem. for the past 3 months once and a while when you turn the key then press the start button, nothing would happen. turn the key back off and back on a couple times then it would work. Recently i turned the key on started it up tried the lights and nothing, turned back off and on then it worked agian. soo is there any way to fix this problem? if not where can i get a different key setup for it. THANKS in advanvce
1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
1982 honda 200 bigred cobra exhaust
1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
