Results 1 to 11 of 11
Thread: kx60 trike conversion
    Dec 2011
    I got a 98 kx 60 for 200 bucks and when i was looking through google at some picks a threewheeler version from the 80s popped up. I checked out some threads htat had this topic to but i would really li8ke to build one. anyone out there know what parts were used or what needs to be made custom for that to be possibleClick image for larger version.
Name:	Screen shot 2011-12-15 at 10 33 33 PM.jpg
    N.E. Ohio
    2,005
    Welcome frist off, please enjoy your search within 3WW. All the best info you could obtain is most likley around here somewhere. Recreating such a build will take research and resources. Goodluck we look forward to your build post and ride report.
    Nov 2011
    East Greenville, Pennsylvania
    465
    I'm sure it's possible. Someone with more knowledge will chime in soon. Good luck! Keep us posted
    1985 Kawasaki Tecate 250 with kx 500cc motor
    1985 Honda ATC 70 custom built with lifan 125cc
    1985 Honda ATC 70 custom powder coat slight mods
    1985 Honda 250sx
    Yamaha zinger 90cc 2 stroke
    1985 Honda 250sx custom green and black build
    1985 Honda 200x
    May 2011
    eden,ny
    3,481
    there was a thread on the subject not very long ago. for the life of me I cant seem to find it. If I do I will post a link
    STL
    3,560
    thats a cute little bike! nice conversion, like a baby tecate almost! good luck on replicating it, it couldnt be too terribly difficult with the right tools and parts to use. Also, WELCOME!!
    Dec 2011
    Thanks for the welcomes i figure machining the triples inst to bad i just would like to know what was used for an axle set up
    Las Vegas, NV.
    2,526
    Baltimore, MD
    6,088
    The main pieces you would need, rear swingarm, rear fender and the front triple trees which would use the stock forks from your bike. There have only been 2 or 3 of these aftermarket conversons found that I know of, making them quite rare. Best of luck in your quest.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Dec 2011
    thanks for all the help im thinking of making the rear end out a trx90 becuase i have one setup already
    Dec 2011
    Does anyone have a tecate 250 they can take some measurements I need on the rear carrier?
    Dec 2011
    New Hampshire
    When you are doing the conversion you should redo any welds where the suspension or swing arm would be. Just to help to be more solid. You might also want to look at youth atvs to find a rear swing arm. Good luck!
