Results 1 to 15 of 16
Thread: suzuki alt125
    Mar 2011
    oswego county ny
    111
    suzuki alt125
    going to pick up a 82 suzuki alt 125 tomorow morning guy said he had it runing 3 or 4 months ago it needs alot of cosmetic tlc but im getting it for a 100$ maybe ill figure out how to get some pics uploaded? are these good wheelers? do they have good power ect? i havent seen many suzuki trikes around so they are some what rare around here. anybody have any pictures of there alt 125's? any info on these common problems things to look out for would be greatly apreciated
    OHIO
    2,857
    Neat trike, I have had a few and still own 2. Very common carb problems...they have a pull button primer that takes a sheet and or leaks around primer knob as mine is doing now. Not a very easy carb to find in good shape and hard to find kits for them. Not sure of the 82 but my 83 has reverse and mega low. Shift pattern is down. Low engages from nuetral up one. Reverse engages in nuetral pulling up on reverse shift lever behind foot shifter. I think them to be a little tipsy...high center of gravity but all around mine have been good to me. I would run it through the gears if it runs..if not still worth it in parts. Don't forget to change oil and it does have a internal oil filter. Have fun.. here is one I had and sold
    Mar 2011
    oswego county ny
    111
    yea the one im gettings pretty rough but if it has spark and compression its worth 100$ the motor is worth it lol. that one looks nice how much did u end up sellin it for?
    Mar 2011
    oswego county ny
    111
ID:	138007 hey guys when i got there it started for a second gave him the 100 bucks brought it home taped up the seat stitched the rear plastics and made half the front fender out of a 55 gallon drum cleaned up pretty nice worth the 100$.... i need to know what the carb specs are for the air screw and the idle if i give it over 1/4 throttle it boggs down and dies and if i give it the throttle to fast it boggs and dies
    OHIO
    2,857
    Quote Originally Posted by ytm200steve View Post
    Check the airbox lid and airfilter. These are really touchy when it comes to the aircleaner and airbox lid. Make sure it is tight and the filter is on.
    Springfield Mo
    3,309
    Make sure to clean the carb good before you even bother trying to adjust it. My rule of thumb is after I clean a carb I run the screw all the way in and back it out 2.5 turns and go from there.
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Mar 2011
    oswego county ny
    111
    just pulled the carb it was clean jets were the correct ones and clean i blew them out anyway. i was playing with the idle screw and got it to start and idle very low was running like sh*t if i touched the gas it would die when i first got it home it was a little rough starting but not bad and ran better then now i could give it about 1/4 throttle if i slowly gave it throttle and i rode it around for a bit i had it idleing and was playing with the air screw it didnt fix the bog didnt even help i remember all my 200s's wouldnt run right with out the air screw in the right spot dont know if this is the same im getting a little ticked off i was just out there cranking for an hr.... it made 2 very small backfires but still started afterwords if i give it gas and pull it over it wont do a thing any suggestions would be apreciated i dont realy understand this little thing with its fuel pump and tank under the seat primer and choke why dose it need all this?
    Mar 2011
    oswego county ny
    111
    could the timming be slightly off usaualy when i have something with the timeing off all it dose is back fire
    Sep 2008
    845 New York
    2,302
    where did you pick that up from?
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    Mar 2011
    oswego county ny
    111
    camilus he had the add up for a while it looked alot worse i got it i taped up the seat made a front fender touched up some rust spots exc.. cant get it running right though it is starting to confuse me any one got a blown up ytm 200 they wanna trade me haha
    Mar 2011
    oswego county ny
    111
    i think my float isnt adjusted correctly when i tipped it over to change the oil some gas come out of overflow and when i put it back down and pulled it over it fired a few times how do i adjust my float? can some one help me i wanna ride this little guy it looks fun
    glendive, montana
    1,822
    well first you will need to pull the carb, it looks like a mikuni carb to me so you should be able to adjust the tang on the float a little bit. The little metal tab the pushes against the needle if you push it a little towards the needle it will allow less fuel into the bowl. Also what you are describing could be a flooding issue, or a cracked intake boot, next time it is running spray carb cleaner all around the intake boot from the carb to the motor. Also before adjusting the float pull the screw that holds the metal plate between the float and the float needle seat which will allow the float seat to be pulled out. There is an o-ring on it that if wore out will allow fuel to keep filling the bowl. give that a try and then let us know.
    Mar 2011
    oswego county ny
    111
    i thought it was flooding to bc when i had it runing it wouldnt go WOT not even close it would stall out if you the gas could bearly give it 1/4 throttle but plug looks dry every time i pull it out i will try adjusting the float
    Quote Originally Posted by muthey View Post
    Monroe MI
    5,787
    glendive, montana
    1,822
    Then it's not flooding, I wouldn't mess with the float, any trike you tip on it's side for a few min then set them back right will drip fuel as you are throwing the floats off whack when it's over. my guess is an air issue either too much or not enough, have you checked air box and air box intake pathways for a rats nest? did you put on a new air filter or clean it yet, also how dirty is the petcock from the fuel tank, and lines? lots of other things to check before you go adjusting the float level. Because if it is spot on and you move it you might never get it back to where it belongs.
