Results 1 to 15 of 28
Thread: New chain saw opinions wanted!
    So I just bought a brand new Husky 576 XP with a 28" bar. I haven't so much as pulled the pull start yet, it's untouched so there is an outside chance I can bring this back. A person who knows just about everything there is to know about chain saws (jeffatc250r) told me I could have done better for the money with a Stihl. The problem is my last saw was a Stihl and I swore I wouldn't buy a Stihl again.
    My Stihl was too small for me from the get-go, but I bought it new and it ran for 5+ solid years fairly well. It did the job, but I wasn't really fond of it.
    What's the general consensus? Where I haven't even started it yet I may be able to swap it if they're feeling generous that day. They don't have to take it back.
    I did some googling really quick and saw nothing but good reviews.
    NY
    3,185
    I bought the box store (lowes) husq 455 rancher ....used it 2 seasons and have been very happy. Mine is for my property management. I am sure the guys that use them for commercial use wouldnt find my happiness.
    Jan 2011
    Brazil, Indiana
    2,087
    Huskys are notoriously way better in the vibration dampening system. They use springs where Stihl uses rubber mounts. The rubber mounts are stronger, but are harder on your hands at the end of a long day.
    The other thing I like about the Huskies are the ergonomics of the handle bars. I have nothing against owning a Husky, but for me we have a Stihl certified tech at work. He stocks any parts we might need in a cabinet at the shop. If I had a Husky I would have to drive 45 miles to order parts.
    You did good on the bar size, with that longer bar you dont have to bend over near as far to cut firewood.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Blossvale NY
    4,563
    Well Fab, I currently own a 346xp, 357xp and 372xpw. The 372 is the full wrap handle version and sports a 75cc engine rather than the 71cc engine of the standard 372xp. I remember hearing ALOT of bad things about the 575xp, (predecessor to the 576xp you have), so that's why I went to the 372xpw. But, I have heard that the 576xp addressed those problems and has done well in real world markets.
    I'm not a logger, but usually find myself processing upwards of 70 cord of firewood for myself and family each year. Some of it is log loads that have same rather large, tough wood to block, on the larger end of the spectrum pushing 30" in diameter. That 372xpw with a 24", round ground chisel, full skip does a spectacular job for me with that bigger stuff. The rest of the time, I fell my own trees and sometimes get into larger ash, hickory and maple. Now, I don't usually grab the big saw unless the job warrants it. Most times, my 357xp with it's 20" bar is quite capable for what I'm doing. Being that you are already looking at 70+cc saws, I won't even get into the 346xp other than to say I have never run a faster saw on wood 8" and under.
    All in all, I have been utterly pleased with all 3 of my pro-grade Husqvarnas. I have owned the 357xp since 2006, 372xpw since '08, and just got the 346xp in mid '09. All have served me flawlessly and reliably. No complaints whatsoever.
    Now, I haven't really run too many Stihl saws, therefore I have nothing to say about them, good or bad. I'm sure they make a fine saw as well otherwise they wouldn't be as popular and successful as they are. My local saw shop deals in Husqvarna AND Stihl. When I initially decided on my first pro-grade saw I was comparing the Husky 357xp to a comparable Stihl. It really came down to ergonomics and feel to me. I find the swept back handles and slim body of the Husky more comfortable to use. The Stihl kinda felt like a basketball with handles to me. But this is just my personal opinion and taste.
    If you like your 576xp, I would stick with it. If you really want to send it back I would consider a 372xpw. I'm not really sure if you will get a better saw for the money with a Stihl. Look carefully at features and construction. For example, most non pro grade Huskys have plastic crankcases/oil tanks rather than the magnesium found on all XP's. Other things like adjustable oiler are important to me as well. Just make sure that "better" saw for the money isn't lacking in features found on the saw you have. You know the old saying about getting what you pay for.....
    Hope this has been of some help....Cheers!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Oct 2011
    Highland Park IL
    39
    I have always used stihls and love them. We bought a couple husqvarnas at work and I did not care the chain brake and tension adjustment on them. You might want to take a look for yourself at the way you pull the side cover off to access the chain, I do not care for it myself.
    Blossvale NY
    4,563
    Quote Originally Posted by daledozer View Post
    Are you talking about pulling the cover to access the chain for replacement? Or something else????
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Wow, thanks guys.
    When I finally narrowed it down to two saws, it came to the 372 or the 576. They are very similar in size, displacement, and horse power. When it came down to it they were almost exactly the same price. The 576 probably had a slight horse power or displacement advantage which is why I went with it. I'm not concerned with weight because I don't use the saw every day.
    An adjustable oiler was a must for my new saw. My Stihl's oiler isn't adjustable and that thing kills chains.
    I saw it with the cover off. The salesman installed the bar and chain in front of me. It looked very similar to my Stihl actually. I never had issues with the bar adjustment mechanism on my Stihl. If you're implying you have to take the cover off to tighten the chain, that is not true.
    Jan 2011
    Brazil, Indiana
    2,087
    Send me your address in a PM and Ill send you a skip tooth chain. I use square files, but you can use your grinder on it and it will work just fine.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Wow, seriously? Thanks man!
    Jan 2011
    Brazil, Indiana
    2,087
    Yup. I buy chain in 100' rolls and spin my own up. Ive got 300' in the garage. Sort of like a roll your own cig. Its alot cheaper.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    OK
    5,450
    455 Husky Rancher here, and love it. Haven't come across anything it won't cut.. Including a few 3 foot trees at the base..
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Oct 2011
    Highland Park IL
    39
    I had problems putting the cover back on is what I'm trying to say I guess. The brake inside the hub on the models we have had to line up perfect and was not always easy to do, maybe I'm not doing it right.
    Blossvale NY
    4,563
    I'm fairly certain the chain brake is a band brake that wraps around the outer clutch drum on all saws equipped with a chain brake no matter the brand. They can be persnickety to get the side cover back on of the cover/brake area is packed with oil soaked saw dust. Also, make sure you didn't accidentally activate the brake when the side cover was off. That'll make putting it back on a pain too..
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    House Springs MO
    5,496
    Sweet saw Fabio. I used to work for a Parks & Rec. department in a small city close to me. We had three saws and two were Husky's and I loved them. I just bought a used saw and tried to find a Husky, but there were none worth buying on craigslist close to me, so I ended up with a old 028 Super Wood Boss. Its a good saw but I would of loved to find a Husky.
