Results 1 to 15 of 27
Thread: 200es low compression (not running)
    North GA
    60
    I've read the forums and have found these could be the causes:
    1) Needs cylinder bored, new piston, new rings
    2) A valve is stuck open
    3) A gasket is blown
    My problem is, I don't know how to tell which one of the above is the culprit. What I've tried so far points to #1. I dropped a little motor oil in the spark plug hole to see if compression was briefly restored. It had high compression for about 2 turnovers. Also, my brother had the trike when it died and he said it started smoking bad and all of a sudden died. The engine was seized up when I got it from him and this happened after he said it started smoking. It was terribly low on oil when I got it. I did get the engine freed up again, but now the compression is low. So, is there any quick test I can do to eliminate #2 or #3 before I have someone tear this thing apart and charge me $45 per hour? Thanks!
    House Springs MO
    5,496
    Low on oil, heavy smoke, seized engine,= Don't waste your time trying to figure out what is wrong, I'll save you the trouble.
    At the very least it has a heavily scared piston and cylinder, but more likely has more wrong with it. It will need to be torn down and inspected. If it were me I would find a good running replacement and swap them out. They made a million of those things so finding a good runner shouldn't to difficult.
    Sarnia, Ontario, Canada
    3,415
    'bkm' is correct..based on the information you have given us.
    Compression test and other testing is irrelevant!!
    Two choices..tear-down, inspect & rebuild or replace.
    Though maybe not so much on the easy to find a replacement since the 200es was a one year model limited to 84. No other engine will interchange..
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    osoyoos bc canada
    1,057
    rip the top end apart your self as long as you dont brake or losse anything you shouldnt screw it up then post pics even as a start just pull the head cover off
    Dec 2007
    Quebec,Canada
    1,014
    Remove CDI cover,turn the motor until the rotor point the pickup coil ( to be at TDC, valve closed),remove spark plug and push air with a air compressor in the hole.Check for air in the exhaust,of carb,ouside th engine or in the crankcase.Anyway,for any of thoses problem you need to remove the top end.....
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    North GA
    60
    Ok, got it running. A buddy of mine offered to do the top end work, so I let him The piston rings had essentially been wielded to the cylinder wall. It was in bad shape. Got another cylinder and a new piston and rings. While he was in there, he replaced the valves too. Put it all back together and it runs! We put a carb rebuild kit in it. It has a problem now when you get to half throttle. It starts sputtering at half throttle and after. Of course, you can't go very fast like this. I know it sounds like a carb issue, but he said he installed the rebuild kit exactly as the shop manual had described, and I trust him. I guess since it's 29 years old, maybe "factory" carb settings shouldn't be used, lol. Any ideas?
    MonkOFox's Avatar
    MonkOFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    texas
    264
    If its the same carb off the bike and not an ebay replacement, it could still have had some gunk and clogged something up. I would just take the carb back apart, remove all the rubber and soak everything in diesel or something.
    after a couple days, blow that stuff out with air and wipe it down really good with alcohol with a link free cloth and put it back together and give it another go.
    1985 200S - fixer upper
    North GA
    60
    It is the original carb. I cleaned it out before I knew the condition of the cylinder and piston and he said he cleaned it while he had it apart doing the rebuild. I read somewhere else that someone was having the same issue and another member mentioned the gas cap may be faulty causing it not to allow enough fuel to flow. I'll remove the cap when I get home and see if it runs better then. If not, I guess I'll pull the carb and look at it.
    Jan 2011
    Avon, Minnesota
    641
    Check for airleaks also
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    North GA
    60
    Ok, here's what happened today. Checked to see if the fuel cap was the issue, it wasn't. Still sputtered at half throttle. So, then I decided to check for air leaks. I looked in the air box and the air filter was just laying in there, so I connected it up and put the top back on. That did seem to help, but still sputtering. I also noticed that there is an exhaust leak. Where the muffler pipe connects to the header pipe, but muffler pipe is cracked. Cracked pretty bad too, almost broken in half. So, I'll doctor that up later to see if it helps. I decided to check the throttle valve. Noticed that there was some gunk in there. Cleaned it up. Also, I noticed that the throttle valve itself had some damage to it, not sure if it's causing my problems. Put it back in and tried again, a little better, but still sputtering. I thought the petcock filter might need to be cleaned. This is where it gets interesting. I pulled the gas tank off and drained the gas in preparation of removing the petcock. The shop manual calls it a "fuel strainer" and it looks like it comes right out when you pull the petcock, but no, it does not. Instead, a tube came out and the fuel strainer stayed in. So, I thought that I could clean it (the fuel strainer) with compressed air. So, that's what I did. I blew air up through the hole the tube came out (which was in the fuel strainer) hoping to blow off any crud stuck to it. I rinsed out the tank and put in some more gas. Put the tank back on, turned on the fuel...now there's fuel coming out the bowl of the carb and pouring into the air box. This was not happening just 15 minutes before. Looks like I'll be pulling the carb this weekend to see if there's anything my buddy missed...unless you guys have another idea.
    ALSO, it doesn't have a battery (I know I shouldn't be running it without one, but they're just so expensive). I need to know if the following is a problem or not. The neutral light does not shine when it is in neutral and running. However, if I turn on the lights, the neutral light comes on. The lights actually get dimmer when it is revved (I thought they should get brighter). Is this just something that happens when my idiot self runs it without a battery? Or, is it something I should check out. (I'll be getting a battery this weekend.)
    Pacific NW
    4,255
    Yeah, a good question I never asked is it ok to run them without a battery?
    Does it overload the regulator/rectifier or other components?
    I ran mine for years without a battery and it worked just fine when I finally did get one.
    So you cleaned the gas tank and strainer and now the carb leaks?
    Overflow? or bowl gasket?
    Sure doesn't take much crud to hang open the float valve.
    I've blown some mystery or 2 stroke oil into the carb fuel inlet
    just with mouth pressure and a new piece of fuel line, especially if you've been in there a few times.
    Just make sure the float bowl drain is open so it has someplace to go.
    See if the following words light up as a clickable link.
    service manual
    wiring diagrams included
    the 200es is famous for questionable electrical connections.
    which could also be part of your hi rev breakdown.
    Check all connections, especially grounds.
    By turning on the lights, it may be forcing a better connection so the neutral light comes on...better.
    Hi rev breakdown could also be as simple as nipping the last tiny bit of sparkplug wire
    that the sparkplug cap screw into so you get some fresh wire to bite into.
    Be careful or you'll wind up with 5 or 10 of these silly things.
    and please keep us posted.
    North GA
    60
    It's leaking out the tube coming out the bottom of the carb. This happened about 12 years ago when i restored it the first time and all i had to do was tap on the bowl lightly to unstick the float. I'll just have to remove the carb because that isn't working. Also, hooked a battery to it and the neutral light comes on now without the lights on. But without a battery, the neutral light barely (and i mean barely) burns. Seems kind of odd. Oh well, got to work graduations next two days so i won't get to look at it until saturday probably. Guess I'll pull the carb and really soak and blast it.
    North GA
    60
    I know my goal should be to keep this thing OEM, but I did get to pull the carb today, it was clean. I did blast it and went to put it together and it is still leaking out the overflow (out the bottom). Thinking about an Ebay carb http://www.ebay.com/itm/Carburetor-C...ht_3396wt_1125. Anyone have any luck with these things?
    North GA
    60
    Ok, pulled the carb again, didn't see anything wrong. Blew out the float valve seat thoroughly, still leaking. So, bought one of those carbs off ebay. I'll stick it on when I get it. Maybe this will also solve the mid to high throttle issue and I can actually get to the cosmetics of the machine.
    North GA
    60
    Apparently when i blew out the petcock it turned all the crud into tiny pieces of crud the can slip through the strainer. Must not have cleaned the tank good enough afterwards. Cleaned it real good and the carb is working now. Still is cutting out thiugh. Check the plug and it was dry, but black. Burning rich. Tried leaning it out by moving the needle a notch, didn't help.
