Results 1 to 15 of 21
Thread: 2 200 motor rebuilds in one day
    osoyoos bc canada
    1,057
    for some reason when i woke up at 5:30 i desided to go to my shop and just go nuts i riped down my 200x 185s and xr 200 motors only the 200x ran but pissed oil from the bottom end gasket now i got a perfect 200x motor and a xr 200 that needs a few bolts
    the 200x i bought knowing it was locked up for $60 a little much but its my total investment in my trike it has a xr200 cylinder carb intake and cam with a 185 head with the manuel decomp the 185 uses the same comp ratio as the 200 but it has a smaller dome in the head and the pistion is dished witch means i get more comp with this head on a 200 this confused me when i first put it on it makes a noticable differice i also have what i beleive to be a bassani pipe for it
    the xr motor i jut put together from what was left 185 cylinder cam intake and a xr head
    torque's Avatar
    torque is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2011
    saskatoon sk canada
    308
    osoyoos bc canada
    1,057
    beer box has never failed me if you dip it in atf overnight it will even work as a head gasket in a sled motor
    glendive, montana
    1,822
    I knew you could use milk cartons in a pinch if needed because of the wax base that is on them, but beer boxes soaked in atf is a new one for me. You truly are bcredneck.
    I like the hatchet engine stand myself
    Quote Originally Posted by muthey View Post
    Yes, but only a SLED motor. Very limited application..... Read up some more will ya
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    ok i was going to say "nice!" but it said post too short so hopefully this will work!
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    osoyoos bc canada
    1,057
    ive only ever needed a head gasket for the sled i try to save them i ran that thing in 30 plus heat all summer before it burnt threw
    May 2011
    eden,ny
    3,481
    so what is rebuilt?
    ^ I believe it is assembling various used pieces with new gaskets into a complete motor from varies parts supplies
    osoyoos bc canada
    1,057
    i had to split the case on the 200x to do that every nut bolt and part came off mostly so i could glue a gasket back together and i put it back together with a few differnt parts neather motor needs rings for a long time ones been done alredy and the other is just mint forgot about the camara when i did the 200x i was busy trying not to losse anything i was also way to lazy to pull the 6 speed swap i would have to make a obama case for that the black and unpainted parts aready piss me of just put the other one togeather with spare parts and made it run had to rip it apart and put it back togeather after 2 i found a c clip from somthing else on my floor
    Cincinnati, OH
    3,289
    Didnt see no new gaskets......
    "MR.Clean"
    Gold Hill, OR
    1,295
    What? No bed frames or garage door hardware applications this time BC? Youre slippin man......... Come on, wheres the street bike powered wheel barrow or maybe a big block snowmobile.
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
    Sarnia, Ontario, Canada
    3,415
    Quote Originally Posted by bcredneck View Post
    i would have to make a obama case for that the black and unpainted parts aready piss me...
    Wait, what..you didn't really say that did you!!! You're gonna represent for us Canadians then leave the racial references to American presidents on your posts..??
    That's just ignorant and offensive!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    6,811
    I seen a brand new budwieser gasket !!!!!
    Quote Originally Posted by Xowner View Post
    Depends who's calling it a new gasket
