Results 1 to 15 of 16
Thread: 185s aluminum front rim?
    kiser's Avatar
    Coshocton Ohio
    525
    Im building a 81 185s for my girlfriend (and me lol) to ride. Im going for a race look. I put 400ex hubs on the rear with aluminum rims and would like to put a aluminum front rim on it. Has anybody ever made one or is there something that i can use from something else that will work with the 185 hub bolt pattern? Thanks for any info
    Nov 2007
    ulysses pa
    1,231
    is it 3 or 4 bolt? i cant remember.... you can still find aluminum wheels its just not easy. you can try to pm vealmonkey, he may have something sitting around. search around on ebay, be creative with your word choices and i think you'll find something.
    Scootertrash's Avatar
    In the sticks
    4,638
    Your stock rim should be 8X8 and the bolt pattern should be 3/100
    After 1981 it was 4/130.
    Would it be easier to get a post 1981 hub for the 4/130?
    6,811
    I have one , 4x130mm bolt pattern , pm me if interested .
    kiser's Avatar
    Coshocton Ohio
    525
    My hub is a 3 bolt. Will a 4 bolt hub swap out or is there something to change? Axle..axle spacers..brakes?
    Baltimore, MD
    6,088
ID:	139612Click image for larger version.
ID:	139613Click image for larger version.
ID:	139614Click image for larger version.
ID:	139615Click image for larger version.
ID:	139616Click image for larger version.
ID:	139617The 3 bolt and 4 bolt 185s hubs are interchangable. All the 3 bolt parts (except the wheel of course) will fit the 4 bolt hub. Do you need a suspension frame???
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    kiser's Avatar
    Coshocton Ohio
    525
    Thanks for the info guys. PM sent on the frame vealmonkey. The lil lady would like suspension better then none with 18in turf tamers LOL!
    Baltimore, MD
    6,088
ID:	139620Click image for larger version.
ID:	139621Click image for larger version.
ID:	139622Click image for larger version.
ID:	139623Click image for larger version.
ID:	139624Click image for larger version.
ID:	139625Here's my bolt on suspension 185s frame with 20" itps'.
    Nicholson 185s
    6,811
    The 3 bolt pattern 3x100 is still avalible and I believe DRATV sells them . Found it and its on sale !!!
    http://www.dratv.com/poalwhbydo83.html
    Quote Originally Posted by kiser View Post
    In the sticks
    4,638
    I found that one too, but it's S.O.S. (Sorry Out of Stock):
    from the link above:
    ATC70_ATC90 POLISHED ALLOY_WHEELS DOUGLAS_8"X8" 3_ON_100mm BOLT_PATTERN (4"/4"_OFFSET) (SOLD_EACH) temp out of stock 8x8/3on100/4x4Regular price: $55.50Sale price: $49.95
    kiser's Avatar
    Coshocton Ohio
    525
    Ill have to pick one of those up when they get some in stock. Im looking forward to getting this lil beast running. Motor work is almost done. I had it bored 80 over with a 12-1 piston, ported, stainless valves, heavy springs, new rockers and I have a mid range cam on the way. A buddy (thanks andy) hooked me up with a PK racing pipe. Im not sure on a carb yet? I want to go bigger but not sure how much? Any suggestions?
    Baltimore, MD
    6,088
    At least a 200s or 200x carb. 12:1 piston should rip your arm out of socket. I've got an engine like that. Better make sure that decomp lever works or get an 82 and later head with the decomp cable or you won't be happy.
    Nicholson 185s
    kiser's Avatar
    Coshocton Ohio
    525
    Good deal! I have a 200x carb...somewhere. I made a aluminum pull handle to start it. Its a flat piece of aluminum bent in a U with a 7/8 id pipe tig welded to it. It shouldnt come out of my hand. My shoulder is the next week point LOL!
    Cincinnati, OH
    3,289
    Good lord why do that for your wifes bike? Now you have to start it every time she wants to ride it! ( still cool none the less) LOL
    "MR.Clean"
    OHIO
    2,857
    Quote Originally Posted by Xowner View Post
    uhhhh.....that would mean maybe he has to ride it instead of her! Let her ride the Tecate Kiser...lol
